Full Wave Bridge rectifier conversion pictures
Goto page 1, 2  Next
Plane Bart
PostPosted: Sun Sep 16, 2012 12:53 pm    Post subject: Full Wave Bridge rectifier conversion pictures Reply to specific post Reply with quote
I got side tracked with an air compressor but did install the
Radio Shack Full wave bridge rectifier part#275-1185 25 amp, 50 volts
a
Drill out the 2 wire cut out relay remove guts, file off the small knub on plate.
Installed heat shrink and spade terminals.
[/img]
View user's profile Yahoo Messenger
Plane Bart
PostPosted: Sun Sep 16, 2012 1:10 pm    Post subject: Re: Full Wave Bridge rectifier conversion pictures Reply to specific post Reply with quote
Generator wire gos to the positive terminal AKA the one opposite of the other three, used a volt meter to determine which terminal to put the battery on chose the one with 6.5 volts DC
36 Coupe
PostPosted: Sun Sep 16, 2012 5:04 pm    Post subject: Re: Full Wave Bridge rectifier conversion pictures Reply to specific post Reply with quote
Cable ends look awful close on the starter switch.Dont forget the diode has a.7 volt drop that produces heat.
souNdguy
PostPosted: Mon Sep 17, 2012 4:21 am    Post subject: Re: Full Wave Bridge rectifier conversion pictures Reply to specific post Reply with quote
you have really got to stop loosing sleep about that pitifull forward voltage drop.
you do realize you are sweating about less than 8w on a case that is designed to dissipate many times that???
W_B
PostPosted: Mon Sep 17, 2012 4:26 am    Post subject: Re: Full Wave Bridge rectifier conversion pictures Reply to specific post Reply with quote
For the uninitiated, non-electrical among us, what's the purpose of this?
gatchelguy
PostPosted: Mon Sep 17, 2012 6:54 am    Post subject: Re: Full Wave Bridge rectifier conversion pictures Reply to specific post Reply with quote
What is a full wave bridge rectifier and what does it do and why is it needed on a 2/9N???
JMOR
PostPosted: Mon Sep 17, 2012 7:08 am    Post subject: Re: Full Wave Bridge rectifier conversion pictures Reply to specific post Reply with quote
gatchelguy wrote:
(quoted from post at 10:54:39 09/17/12) What is a full wave bridge rectifier and what does it do and why is it needed on a 2/9N???
It is just 4 diodes in a common package, wired to provide rectification of 2 wire AC input & yield 2 wire DC output, which has nothing to do with the application in the tractor. People use it to replace the electromechanical cut out on 9N/2N tractors. It is just a readily available diode from the omni-present Radio Shack Stores. They don't sell a single high current diode, but do sell the 4 diode bridge package for high current, so people buy it, connect one of the 4 diodes & let the other 3 sit idle. The 1 connected diode acts like a check valve in that it lets current flow from generator into battery, but prevents the reverse, i.e., prevents the battery from discharging into the generator.
Wings
PostPosted: Mon Sep 17, 2012 7:29 am    Post subject: Re: Full Wave Bridge rectifier conversion pictures Reply to specific post Reply with quote
Are you not aware that only 1 of the 4 diodes in a bridge rectifier package is being used?
A single diode is all you need to prevent the battery from discharging back through the generator due to a bad cut out relay.
souNdguy
PostPosted: Mon Sep 17, 2012 7:47 am    Post subject: Re: Full Wave Bridge rectifier conversion pictures Reply to specific post Reply with quote
solid state cut out.. it's a 1 way electron valve.. Smile
Mr. T. Minnesota
PostPosted: Mon Sep 17, 2012 11:11 am    Post subject: Re: Full Wave Bridge rectifier conversion pictures Reply to specific post Reply with quote
JMOR,
What is the total cost of the bridge rectifier? I have a complete single diode unit on two 6 volt systems at the cost of about $30.00 each. There is no fabrication involved. Just curious!!
Mr. T. Minnesota
JMOR
PostPosted: Mon Sep 17, 2012 1:29 pm    Post subject: Re: Full Wave Bridge rectifier conversion pictures Reply to specific post Reply with quote
Mr. T. Minnesota wrote:
(quoted from post at 15:11:05 09/17/12) JMOR,
Mr. T. Minnesota
Her is 50A for about $5. Many on their site.
http://www.radioshack.com/product/index.jsp?productId=12678415
Plane Bart
PostPosted: Mon Sep 17, 2012 1:32 pm    Post subject: Re: Full Wave Bridge rectifier conversion pictures Reply to specific post Reply with quote
Full wave bridge rectifier was $5.00 bucks
Hobo,NC
PostPosted: Mon Sep 17, 2012 4:23 pm    Post subject: Re: Full Wave Bridge rectifier conversion pictures Reply to specific post Reply with quote
Nice post I have never been their it clears it up...
JMOR
PostPosted: Mon Sep 17, 2012 4:34 pm    Post subject: Re: Full Wave Bridge rectifier conversion pictures Reply to specific post Reply with quote
Hobo,NC wrote:
(quoted from post at 20:23:27 09/17/12) Nice post I have never been their it clears it up...
If you leave a bit more of the original cut out base, then it will look virtually stock, like this:
http://www.tractorshed.com/cgi-bin/gallery/gallery_pic.cgi?pic=http;//www.tractorshed.com/gallery/pieces/v762.jpg&firstrec=5&Parameter=cutout&w=pieces&cc=0
http://www.tractorshed.com/cgi-bin/gallery/gallery_pic.cgi?pic=http;//www.tractorshed.com/gallery/pieces/v764.jpg&firstrec=5&Parameter=cutout&w=pieces&cc=1
36 Coupe
PostPosted: Tue Sep 18, 2012 2:40 am    Post subject: Re: Full Wave Bridge rectifier conversion pictures Reply to specific post Reply with quote
You dont know much about old Ford generators.They were rated at 70 watts and wound with a #17 wire in the armature.They tended to burn running at 8 volts.Loose connections in the charging circuit let the voltage climb.Do you know that turning on the head lights too soon after starting the engine would burn out the bulbs on a Ford car with a 3 brush generator in cold weather.
Goto page 1, 2  Next
Page 1 of 2
