cylinder head leak
greg3888
Guest
PostPosted: Mon Sep 17, 2012 5:23 pm    Post subject: cylinder head leak Reply to specific post Reply with quote
My to20 has a coolant leak in the cylinder head. the leak is around the outside were the tubes that the push rods go thru. these tubes dont look cast.they look pressed in. I was wondering ifthey were a cast part of the head or if they were a tube that is pressed in and may be a place that may leak. thenk you , Greg
NWBuckeye
PostPosted: Mon Sep 17, 2012 5:55 pm    Post subject: They are Pressed in Tubes, not Cast into the Head. Reply to specific post Reply with quote
No big deal to replace with a press.
JPFL
Guest
PostPosted: Tue Sep 18, 2012 4:42 am    Post subject: Re: cylinder head leak Reply to specific post Reply with quote
I have a good used head if yours is bad. Jim --No-Advertising-in-Forums
2tractors
PostPosted: Tue Sep 18, 2012 4:43 am    Post subject: Re: cylinder head leak Reply to specific post Reply with quote
I have a to20 head that has a crack under the valve spring. If it's not possible to order the tubes then I'll sell you mine for $50 plus shipping.
John(UK)
PostPosted: Tue Sep 18, 2012 6:09 am    Post subject: Re: cylinder head leak Reply to specific post Reply with quote
The tubes are pressed in and then flared with a tool to clamp them into the head. But I don't think that they will cause water to leak if they are damaged, I think that you will need to look more closely at that, it is possibly a cracked Head that is causing your problem..John(UK)
