Farmall 100 Front Blade
Lewis Smith
PostPosted: Sun Oct 07, 2012 10:41 am    Post subject: Farmall 100 Front Blade Reply to specific post Reply with quote
Almost impossible to find a front blade down south, so built my own! Too much for the 100, do you think?
Lewis Smith
PostPosted: Sun Oct 07, 2012 10:44 am    Post subject: Re: Farmall 100 Front Blade Reply to specific post Reply with quote
Didn't add pictures! Try again!
Rod51M
PostPosted: Sun Oct 07, 2012 11:31 am    Post subject: Re: Farmall 100 Front Blade Reply to specific post Reply with quote
Not sure if it is too much or not, but it does look like some good engineering!
Lucid
PostPosted: Sun Oct 07, 2012 11:33 am    Post subject: Re: Farmall 100 Front Blade Reply to specific post Reply with quote
Nice blade you built! Best test is to find you a big pile of dirt. Smile
Lewis Smith
PostPosted: Sun Oct 07, 2012 2:35 pm    Post subject: Re: Farmall 100 Front Blade Reply to specific post Reply with quote
Thanks guys! It actually works really well. The hydraulics have "down pressure" so you can make it dig in as much or as little as you like.
mkirsch
PostPosted: Mon Oct 08, 2012 5:34 am    Post subject: Re: Farmall 100 Front Blade Reply to specific post Reply with quote
Might consider adding a replaceable cutting edge at some point but other than that... Like it.
Sparky2
Guest
PostPosted: Mon Oct 08, 2012 6:45 am    Post subject: Re: Farmall 100 Front Blade Reply to specific post Reply with quote
Blade looks good, I cannot tell fromn the pics, did you break a piece of metal or weld pieces together?
The Dukester
PostPosted: Mon Oct 08, 2012 8:15 am    Post subject: Re: Farmall 100 Front Blade Reply to specific post Reply with quote
Looks okay, but I would suggest that if you ever build another one to make more curvature to the blade and this would give more "shear" angle where the blade contacts the ground. Your blade is pretty "abrupt" at the lower edge IMHO.
Lewis Smith
PostPosted: Mon Oct 08, 2012 4:46 pm    Post subject: Re: Farmall 100 Front Blade Reply to specific post Reply with quote
I had a local company that produces large diameter pipe to bend the 1/4" plate in a sheet metal brake.
Lewis Smith
PostPosted: Mon Oct 08, 2012 4:49 pm    Post subject: Re: Farmall 100 Front Blade Reply to specific post Reply with quote
Thanks for the suggestion. I actually built this one using the radius from an old piece of a IH Cub front blade. Its main purpose is to push brush piles but I have used one I built previously that was very similar and it cuts into the dirt quite well.
Lewis Smith
PostPosted: Mon Oct 08, 2012 4:51 pm    Post subject: Re: Farmall 100 Front Blade Reply to specific post Reply with quote
Yeah, you are probably right but I can turn this blade over if I ever use it enough to wear one side out. I built it so it is reversible and I can angle one side out to turn the dirt.
