oil filter leaking
ann Budzinski
PostPosted: Wed Nov 14, 2012 5:55 am    Post subject: oil filter leaking Reply to specific post Reply with quote
I have a 560 Farmall tractor. I finally got the oil filter canister to
stop leaking from the base, but cannot stop the leak from the top
nut at the copper washer. Any ideas anyone???
rustyfarmall
PostPosted: Wed Nov 14, 2012 6:47 am    Post subject: Re: oil filter leaking Reply to specific post Reply with quote
ann budzinski wrote:
(quoted from post at 06:55:11 11/14/12) I have a 560 Farmall tractor. I finally got the oil filter canister to
If you have already replaced that copper washer and it still leaks, chances are good that someone. at some point, has over-tightened the bolt, and thus the top of the canister is now mis-shaped and collapsed. Easiest way to fix that is to find another canister.
d beatty
Guest
PostPosted: Wed Nov 14, 2012 6:52 am    Post subject: Re: oil filter leaking Reply to specific post Reply with quote
I have had the same problem with one one an M and 706. You could try a new washer or I had better results using a nylon washer.
greygoat
PostPosted: Wed Nov 14, 2012 8:07 am    Post subject: Re: oil filter leaking Reply to specific post Reply with quote
Double washers ??? or, add nylon washer.
ericlb
PostPosted: Thu Nov 15, 2012 4:43 am    Post subject: Re: oil filter leaking Reply to specific post Reply with quote
like the others have said the nylon gasket should help, take the old one with you to a good auto parts store, [carquest or napa] they usualy have a box of these and can size one up like yours so you get the proper inside and outside diameters,
ann Budzinski
PostPosted: Thu Nov 15, 2012 7:16 am    Post subject: Re: oil filter leaking Reply to specific post Reply with quote
thank you so much. I'll buy a nylon washer and try it.
Southern Ray
PostPosted: Thu Nov 15, 2012 6:11 pm    Post subject: Re: oil filter leaking Reply to specific post Reply with quote
mine was leaking too when I got it.
copper washer would not hold.
finally straighten it out best as I could with a brass rod and hammer.
I then brazed a thick washer onto the top.
Took it down to a local machine shop and had him put it in a lathe and true up the top of the washer.
haven't had any problems since.
ann Budzinski
PostPosted: Fri Nov 16, 2012 8:59 am    Post subject: Re: oil filter leaking Reply to specific post Reply with quote
I went to NAPA, Advanced Auto, Fastenal, and TSC...nobody has nylon washers that size! The washer doesn't look like anything is wrong with it. The NAPA guy suggested I use sandpaper to clean it up and try it again. Hate to go to the Farmall store and pay $6 for a washer! Sad
ann Budzinski
d beatty
Guest
PostPosted: Fri Nov 16, 2012 11:53 am    Post subject: Re: oil filter leaking Reply to specific post Reply with quote
There is a another way to stop it. Get an o ring that fits under the head of bolt and another one put between washer and canster. This has allways worked for me . You want to keep extra o rings because you will have to replace them every time you change oil filter.
WGM
PostPosted: Wed Nov 21, 2012 3:07 am    Post subject: Re: oil filter leaking Reply to specific post Reply with quote
How much gas have you used running around trying to save a buck? Do yourself a favor and get the correct part or get used to the leak.
