dearborne 6 ft disc
david1
Guest
PostPosted: Thu Nov 15, 2012 7:55 pm    Post subject: dearborne 6 ft disc Reply to specific post Reply with quote
Plate with serial number say pull-F . and it has 2 places to put a hitch pin thru. can anybody tell me whats thats all for. The one hook up place is staight out from the frame and the other place kind of goosenecks up from the first row of disc. thanks
Leroy
PostPosted: Fri Nov 16, 2012 5:17 am    Post subject: Re: dearborne 6 ft disc Reply to specific post Reply with quote
You are missing the control part that adjusts the gangs. Part hooks to a swinging drawbar abd the other part hooks to the 3 point arms. When you raise the arms it changes the gang angle. Need to find both a operators manual and parts manual.
david1
Guest
PostPosted: Fri Nov 16, 2012 6:08 am    Post subject: Re: dearborne 6 ft disc Reply to specific post Reply with quote
Leroy, any idea where I can get those. I did find some pics in a Dearborn ad for a type c disc. does the hitch just hook up to a bar between the 3 point lift arms? I would bost a pic of what I got but I have never been able to figure out how to get in to go on this site. I can send you one thru email. Do you know if these are good working disc? thanks
Leroy
PostPosted: Fri Nov 16, 2012 7:05 am    Post subject: Re: dearborne 6 ft disc Reply to specific post Reply with quote
Just seen them in pictures but I do have a parts book around, just where? Can't post link but email me and will tell you address to try to get those books.
david1
Guest
PostPosted: Fri Nov 16, 2012 7:15 am    Post subject: Re: dearborne 6 ft disc Reply to specific post Reply with quote
I found a manuel on the internet. It shows the disc hooked to a tractor that I think is an 8n. The disc is hooked to what they call 'Y" frame and the tractor does not have a swinging drawbar. Do you think the disc will work the same hooked to a regular swinging draw bar that I have on my 4600 Ford.
Leroy
PostPosted: Fri Nov 16, 2012 3:57 pm    Post subject: Re: dearborne 6 ft disc Reply to specific post Reply with quote
You need the parts manual and the operators manual to figure out just what parts you do have and what is missing and that will tell you how to do the hookup. I know there are different hitch setups but do not know how to use them as I do not have the disk. Would not mind having one but do not.
Leroy
PostPosted: Fri Nov 16, 2012 4:03 pm    Post subject: Re: dearborne 6 ft disc Reply to specific post Reply with quote
Anything with the Dearborn name shown in manuals or advertisements will be shown with either an 8N or a NAA as those 2 models are all that was built when the Dearborn name was used on machinery. And the machinery was built from 1948 to 1954, after that 1955 and up will carry the Ford name.
