Author |
Message |
newmmfan Guest
Posted: Sun Apr 22, 2007 9:24 am Post subject: cannot afford that |
Well thanks everybody for the info on collecting MM. I can see after my research that I cannot afford a UDLX, maybe sometime. What would be something a starter collector could buy for maybe up to $3000-$4000 and still use it here on the " Hobby Farm ". I think the bright yellow MM's are so sharp ! and they sound like a dozer coming at you ! any ideas ? |
Back to top |
schrocky Guest
Posted: Sun Apr 22, 2007 9:33 am Post subject: Re: cannot afford that |
Hey, caught ya there just before leaving the site. Thanks for calling me about the auction. There are lots of nice MM 's that can be bought in your price range I am sure. I would look into buying something built in the early to mid 60's. To get into the Industrial yellow you refered to you need to buy M6 series, U302, G1000, G900, G706,G705,G707 type tractors. M6, Jet Star 3, U302 are all purpose and can be hauled to shows etc pretty easy. Guys if you have any ideas jump in here and help this guy. See you in June |
Back to top |
Clint Youse MO Guest
Back to top |
ted regentin` Guest
Posted: Sun Apr 22, 2007 5:05 pm Post subject: Re: cannot afford that |
I would suggest anything in the 335 or 445 series. Generally one can be found with power steering and three point hitch. Parts arn't a problem, and 1959 was the last year so I would think they will maintain or increase in value. Mine works very well for disking and snow removal. Just my two cents worth. |
Back to top |
Moline_guy Guest
Posted: Sun Apr 22, 2007 5:22 pm Post subject: Re: cannot afford that |
The G1000 were good tractors and fairly easy to work on, and would be in your price range, one thing to watch for when buying a diesel model is to check the radiator while it is running and cool by holding your palm over the opening with the cap off, if it has compression might be a sign of cracked head. Other than that they don't have a lot of issues, good luck whatever you decide to buy, and post a picture when you find one, take care. |
Back to top |
newmmfan Guest
Posted: Sun Apr 22, 2007 5:55 pm Post subject: Re: cannot afford that |
Wow thanks for all the replies, I do want a 3 pt and live PTO and I do like the Brown belly tractors with the school bus yellow colors. Does that narrow it down too much ? HP would be enough to run a 6-8ft bush hog and I want something I can haul behind a pickup truck to shows.Do you support buying at an auction or am I better off buying from a dealer or individual ? You guys are great and Thanks again. |
Back to top |
schrocky Guest
Posted: Mon Apr 23, 2007 1:49 am Post subject: Re: cannot afford that |
Knowing all that narrows you down a little more. Jet Star 3(which maybe all yellow somebody help here please),M602,Early M670,Early G1000 , now remember it may not be right but you can paint them anyway you want...it is yours ! |
Back to top |
Clint YOuse MO Guest
Back to top |
Mopower Guest
Posted: Mon Apr 23, 2007 9:35 pm Post subject: Re: cannot afford that |
On a hobby farm I'd say find a Jet Star. Even better if you find a Jet Star 3 Super. Small, handy, and powerful!!! If you need more power, a 5-star through M670 Super are all neat. I play with the oldies though. |
Back to top |
Fancy Farm Guest
Posted: Tue Apr 24, 2007 3:53 pm Post subject: Re: cannot afford that |
Go to Aumanauctions.com look at the Robert Elliot estate auction and you can locate any of the above (except the ULDX) from the GVI down. |
Back to top |
Rexalot Guest
Posted: Wed Apr 25, 2007 10:17 pm Post subject: Re: cannot afford that |
Our Jetstar 3 super is all yellow (with the black and white striping) |
Back to top |
tplanefun Guest
Posted: Thu Apr 26, 2007 8:27 pm Post subject: Re: cannot afford that |
I have a jetstar 3 plain/econo (5 speed no T/A). I use if just for what you want to do. It is a 1965 with the brown engine/ belly and yellow sheet metal. The 206 engine was used in alot of MM"s so parts are not to hard to come by. There are alot of jet stars, 445"s & 4 stars around in good shape. Good luck |
Back to top |
