Ford 2000 Offset
Goto page 1, 2, 3, 4  Next
daverd4
PostPosted: Sat Jan 12, 2013 3:17 pm    Post subject: Ford 2000 Offset Reply to specific post Reply with quote
Can any body help decode this new to me tractor? Never seen a Ford with this many numbers on it.
21111G
74596
6J28
Thanks
mhb@ufe
PostPosted: Sat Jan 12, 2013 3:34 pm    Post subject: Re: Ford 2000 Offset Reply to specific post Reply with quote
This is from John Smiths web site.
Decoding the 5 digit model numbers on 2000-4000 series tractors -
First number (1 digit)
2**** - 134 ci gasoline or 144 ci diesel engine
4**** - 172 ci gas, LP-gas or 172 ci diesel engine
Second number (1 digit)
*0*** - Industrial models produced prior to 1963
*1*** - Industrial and agricultural models produced after 1963
Third number (2 digits)
**10 * - Row crop
**11 * - Offset
**20 * - Utility-type w/adjustable front axle
**21 * - Orchard type w/ non-adjustable front axle
**30 * - Utility-type tractor w/non-adjustable front axle (light industrial)
**31 * - Low center of gravity (LCG tractor)
**40 * - Heavy duty industrial tractor w/sub frame **41 * - Heavy duty industrial tractor w/sub frame & cast grille Last number (1 digit) *1**0 - Four-speed w/o PTO *0**1 - Four-speed w/o PTO or hydraulics *1**1 - Four-speed w/PTO *0**2 - Four-speed w/hydraulics, w/o PTO *1**2 - Five-speed w/live PTO *0**3 - Four-speed w/hydraulics and PTO *0**4 - Select-O-Speed w/o hydraulics or PTO *1**4 - Select-O-Speed w/o PTO *0**5 - Select-O-Speed w/hydraulics and single-speed (540 rpm) PTO *0**6 - Select-O-Speed w/hydraulics, 540 and 1000 rpm PTO and ground-speed PTO *1**6 - Select-O-Speed w/two-speed (540 and 1000 rpm) independent PTO *1**7 - Select-O-Speed w/540 and 1000 rpm independent PTO and ground-speed PTO *0**9 - Five-speed w/live PTO Suffixes -1 - Tricycle with single front wheel -4 - High clearance with wide front -L - LP gas engine -D - Diesel engine Thousand Series tractor serial numbers - 1962 Serial number 1001 - 11947 1963 Serial number 11948 - 38930 1964 Serial number 38931 - up Part number identifiers cast into 134 and 172 engine blocks (lower right side) EAE 6015 - 134 1953-1957 EAF 6015 - 172 1953-1957 310905 - 134 1958-1959 310609 - 172 1958-1959 B9NN-6015C - 134 late 1959
Mark
souNdguy
PostPosted: Sat Jan 12, 2013 3:41 pm    Post subject: Re: Ford 2000 Offset Reply to specific post Reply with quote
common set for the 63-64 000 models..
daverd4
PostPosted: Sat Jan 12, 2013 3:50 pm    Post subject: Re: Ford 2000 Offset Reply to specific post Reply with quote
Well I got the first number but not the G at the end. 2nd # must be serial number. Whats the last number? Is the G the month bilt in the 1st #?
mhb@ufe
PostPosted: Sat Jan 12, 2013 3:52 pm    Post subject: Re: Ford 2000 Offset Reply to specific post Reply with quote
This is probably the one you need, the G transmission cod not shown is a 4x4 manual.
NEWER TRACTORS
('65 TO '75) MODEL
NUMBERING
Model ID
Previous.................Newer
'65 to 3-'68...........4-'68 to 1975
2---------2000--------B
3---------3000--------C
4----------4000--------D
5----------5000--------E
Chassis Type
10 - Agricultural All Purpose
11 - L.C.G.
12 - Highway
13 - Rice
20 - Row Crop
30 - Vineyard
31 - Narrow
40 - Utility
50 - Industrial
Fuel Type
1 - Diesel
2 - Gas
3 - L.P.
PTO
1 - No PTO
2 - Trans 540
3 - Live 540
4 - Independent 540
5 - Independent 540-1000
6 - Independent 540/1000 GD
Tramission Type
A - 4 speed
C - 8 speed
E - Select-O-Speed
F - 4/4 T-C Power Reversing
K - 6/4 Manual Reversing
MODEL NO EXAMPLE
Switch to LH Side
Click on round picture to see an example on a Ford 3000 tractor.
Change your Printer setup to Landscape then Ctrl-P to print this page.
VIN ID
TRACTOR
HYDRAULIC ENGINE
PRODUCTION CODES
Year
1965 - 5
1966 - 6
1967 - 7
1968 - 8
1969 - 9
1970 - 0
1971 - 1
1972 - 2
1973 - 3
1974 - 4
Month
JAN - A FEB - B
MAR - C APR - D
MAY - E JUNE - F
JULY - G AUG - H
SEPT - J OCT - K
NOV - L DEC - M
Day
Numerical Date 1 through 31
Shift
Midnight - A
Day - B
Afternoon - C
PRODUCTION CODE EXAMPLE
Mark
mhb@ufe
PostPosted: Sat Jan 12, 2013 3:58 pm    Post subject: Re: Ford 2000 Offset Reply to specific post Reply with quote
The last number is the production date.
6=1966
J=Sept
28=28th day
Mark
souNdguy
PostPosted: Sat Jan 12, 2013 4:32 pm    Post subject: Re: Ford 2000 Offset Reply to specific post Reply with quote
and you think those 65+ codes apply to a 64 4 cyl offset.
you let me know when you find a 4x4 MR in one of those. Smile
mhb@ufe
PostPosted: Sat Jan 12, 2013 4:36 pm    Post subject: Re: Ford 2000 Offset Reply to specific post Reply with quote
I think he has a 1966 tractor.
Mark
souNdguy
PostPosted: Sat Jan 12, 2013 4:53 pm    Post subject: Re: Ford 2000 Offset Reply to specific post Reply with quote
I'm not aware of too many offset tractors from ford.
541, 2000 ( 4 cyl!!! 63-64) offset and I believe a 1710
mhb@ufe
PostPosted: Sat Jan 12, 2013 5:01 pm    Post subject: Re: Ford 2000 Offset Reply to specific post Reply with quote
Look at his date code, and the model number indicates an LCG not an offset so There seems to be some confusion.
Mark
souNdguy
PostPosted: Sat Jan 12, 2013 5:04 pm    Post subject: Re: Ford 2000 Offset Reply to specific post Reply with quote
he said he had an offset.. that's what I went off of and why I chose the 63/64 4 cyl as it would be a 2000 as a possibility.
he said he had an offset... if's he's such a moron he can't tell the difference between a tractor setting real low, or one with different length axle trumpets.. then he needs to hurry up and sell it. it's gonna ba a hard uphill row for him to hoe....
mhb@ufe
PostPosted: Sat Jan 12, 2013 5:15 pm    Post subject: Re: Ford 2000 Offset Reply to specific post Reply with quote
He sure has something wrong as I first thought 63-64 same as you but the date code tells me 66 so I think we need a picture or a better description.
Mark
souNdguy
PostPosted: Sat Jan 12, 2013 5:31 pm    Post subject: Re: Ford 2000 Offset Reply to specific post Reply with quote
agreed, for sure...
Sean in PA
PostPosted: Sat Jan 12, 2013 6:09 pm    Post subject: Re: Ford 2000 Offset Reply to specific post Reply with quote
If 21111G is correct, then it would be a 3 cylinder 200 series
2 = 1965-1968 2000 series
first 11 = Low Center of Gravity chassis
Next 1 = diesel engine
Next 1 = No PTO
G = 4x4 manual reversing transmission
And the serial number would be incomplete. 74596 looks like part of a '65-'75 serial number Should be a letter followed by 6 numbers.
The date code looks to be a '65-'75 type as well. 6J28 = September 28, 1966
The earlier 4 cylinder 2000 series only had 2 numbers stamped on the flat spot, so it is not likely a 4 cylinder 2000, but who knows who might have stamped something on there at some point.
We really need to ask daverd4 - Is this a 3 or 4 cylinder tractor? Can you post some pictures?
Larry NCKS
PostPosted: Sat Jan 12, 2013 6:25 pm    Post subject: Re: Ford 2000 Offset Reply to specific post Reply with quote
Page 1 of 4
