Oil Seal Part No. Cross Ref
F4RM@11
PostPosted: Fri Jan 25, 2013 3:56 pm    Post subject: Oil Seal Part No. Cross Ref Reply to specific post Reply with quote
I'm trying to cross the following part numbers against National or another brand at Advance Auto:
377788R91 - Oil seal, rear axle
358812R91 - Oil seal, PTO
169948C91 - Oil seal, bull pinion
I have a $50 off coupon and another 20% with their current special that's only good online that I'd like to use for parts if possible.
View user's profile Visit poster's website
neblinc
PostPosted: Fri Jan 25, 2013 4:24 pm    Post subject: Re: Oil Seal Part No. Cross Ref Reply to specific post Reply with quote
You can go here
SKF
To find your seals.
Randy
Duner Wi
PostPosted: Fri Jan 25, 2013 4:59 pm    Post subject: Re: Oil Seal Part No. Cross Ref Reply to specific post Reply with quote
Look at these and compare,Victor #s
377788R91 - Oil seal, rear axle=49618
358812R91 - Oil seal, PTO=46257
169948C91 - Oil seal, bull pinion=46179 or49451
Brownie 450
PostPosted: Fri Jan 25, 2013 5:23 pm    Post subject: Re: Oil Seal Part No. Cross Ref Reply to specific post Reply with quote
377788R91
Nat. 417316
C/R 27362
358812R91
Nat. 6200
C/R 13676
169948C91
Nat. 472636
C/R 22441
D Slater
PostPosted: Fri Jan 25, 2013 5:26 pm    Post subject: Re: Oil Seal Part No. Cross Ref Reply to specific post Reply with quote
Think I have the national numbers at the tractor shed for 2 of them, Don't recognize the bull pinion number. What tractor is it for? If no answer by morning I will look. Other two will fit a M and others, if the bull pinion seal is for a M I should have a national #.
F4RM@11
PostPosted: Fri Jan 25, 2013 5:28 pm    Post subject: Re: Oil Seal Part No. Cross Ref Reply to specific post Reply with quote
Thanks, all. I'll check these out to see what's available. It's a '53 SM.
Tom Fleming
PostPosted: Sat Jan 26, 2013 4:41 am    Post subject: Re: Oil Seal Part No. Cross Ref Reply to specific post Reply with quote
go here:
http://www.napaonline.com/
in the upper right hand corner near the SEARCH box is a check-box that says interchange. Put the IH part number in, check the box, and submit the search. They don't cross every part, but I have found alot this way
F4RM@11
PostPosted: Sat Jan 26, 2013 5:15 am    Post subject: Re: Oil Seal Part No. Cross Ref Reply to specific post Reply with quote
Tom Fleming wrote:
(quoted from post at 05:41:32 01/26/13) go here:
Thanks, Tom. I've found Napa's interchange to be very good too. I found seals for the bull pinions at Advance Auto and was able to use my discount.
Bkpigs
PostPosted: Sat Jan 26, 2013 6:02 am    Post subject: Re: Oil Seal Part No. Cross Ref Reply to specific post Reply with quote
If you go to national's website, they have a cross reference
search.
