D3B Hydraulic Steering Valve Plumbing
Confused Plumber
Guest
PostPosted: Thu May 03, 2007 12:24 pm    Post subject: D3B Hydraulic Steering Valve Plumbing Reply to specific post Reply with quote
Need to be "unconfused". Redid the steering valves on my D3B. I'm confused about how to attach hydraulic hoses.
There is one hose coming from oil filter and one returning to sump. I also have 2 tees and each steering valve has 2 inboard connections.
How do these things get plumbed together???
Yes, I know should have taken pictures....BUT
Thanks in advance!
Bob/Ont
Guest
PostPosted: Thu May 03, 2007 2:35 pm    Post subject: Re: D3B Hydraulic Steering Valve Plumbing Reply to specific post Reply with quote
I am about as confused, but the one coming from trans is supply and the other one is drain. Lay the steel lines in there and try to find where they match up to the fittings. If you post a serial# might be able to get a parts pic in a day or two. Peddal steer or lever steer?
Later Bob
Confused Plumber
Guest
PostPosted: Fri May 04, 2007 3:47 am    Post subject: Re: D3B Hydraulic Steering Valve Plumbing Reply to specific post Reply with quote
Bob:
Serial # 27Y....... Think its an 84-86 machine. Has 3F/3R. Pedal steering.
Let me know if this helps. If not can get the whole serial number etc.
Those diagrams will sure be a BIG HELP!
THANKS!
Bob/Ont
Guest
PostPosted: Fri May 04, 2007 6:18 pm    Post subject: Re: D3B Hydraulic Steering Valve Plumbing Reply to specific post Reply with quote
Yes that is good email me please.
Later Bob
Bob/Ont
Guest
PostPosted: Sat May 05, 2007 4:43 pm    Post subject: Re: D3B Hydraulic Steering Valve Plumbing Reply to specific post Reply with quote
Rear most port is supply center port goes to cyl and front port is drain back to trans.
Later bob
