1928 D spark plug hole thread size and plug #?
Canadian Ken
PostPosted: Sun Mar 17, 2013 7:49 pm    Post subject: 1928 D spark plug hole thread size and plug #? Reply to specific post Reply with quote
What thread size is the spark plug holes in a 1928 D -serial #71371 - 6-3/4" bore block -mine are rusty, and I would like to run a tap through before installing the head
What spark plugs do guys use? I did have plugs in 2002 when I dismantled the tractor -they were two piece, but I cannot locate these now- I also moved the tractor from one shop to another since then -all other parts are still here.
Thanks in advance
Ken
LarrySTN
PostPosted: Sun Mar 17, 2013 9:17 pm    Post subject: Re: 1928 D spark plug hole thread size and plug #? Reply to specific post Reply with quote
Your D should have 1/2 inch pipe thread for the spark plugs.
John T
PostPosted: Mon Mar 18, 2013 4:15 am    Post subject: Re: 1928 D spark plug hole thread size and plug #? Reply to specific post Reply with quote
The original plug was a Champion 7 and 7/8 pipe threads as posted....You may find some on Flea bay or most tractor shows have antique plug vendors....
John T
LarrySTN
PostPosted: Mon Mar 18, 2013 4:35 am    Post subject: Re: 1928 D spark plug hole thread size and plug #? Reply to specific post Reply with quote
John T, the 7/8 plug you mention was used at serial number 109944 and after, which is a 7/8 14 plug. The plug he is looking for is 1/2 inch pipe thread (serial number 30400 - 109943) . That would be todays champion 25 or autolite 3695
John T
PostPosted: Mon Mar 18, 2013 4:41 am    Post subject: Re: 1928 D spark plug hole thread size and plug #? Reply to specific post Reply with quote
MY Bad, I had 1/2 written right in front of me but typed in 7/8 by habit grrrrrrrrrrrrrrrrrr
Thanks
JT
gtx1967jewison
PostPosted: Mon Mar 18, 2013 5:08 pm    Post subject: Re: 1928 D spark plug hole thread size and plug #? Reply to specific post Reply with quote
REMEMBER pipe thread is tapered! Do not go more rhan a tiny scrape with a tap or it will be oversized & your block is damaged.
Canadian Ken
PostPosted: Tue Mar 19, 2013 11:20 am    Post subject: Re: 1928 D spark plug hole thread size and plug #? Reply to specific post Reply with quote
right -thanks -i think i will just use a round steel brush instead -it is just surface rust
ken
