tractor cab heater motor
Merle Brendeland
PostPosted: Mon Apr 01, 2013 4:05 pm    Post subject: tractor cab heater motor Reply to specific post Reply with quote
I have a Cozy Cab aftermarket cab which includes a wall mount heater with coolant in and out of the box. Rectanglular box with blade fan heater and around 4" depth. The motor needs replacement. No manufacturer name on motor. Have been to auto parts stores and no matching size.
Anyone have ideas where I could get a replacement motor?
Thanks
Bob
PostPosted: Mon Apr 01, 2013 4:19 pm    Post subject: Re: tractor cab heater motor Reply to specific post Reply with quote
Auto parts store COULD have helped you if they dug out their old paper catalogs of heating and cooling products for older autos and/or Ag/Industrial/Off-road/Heavy trucks.
If you can"t get them to look, post back with picture and/or dimensions and shaft diameter and length. I"ve got the catalogs, if needed.
notjustair
PostPosted: Mon Apr 01, 2013 4:29 pm    Post subject: Re: tractor cab heater motor Reply to specific post Reply with quote
My first thought is that it likely is the same size they use in the hurri-heaters in school buses. You should try schoolbuspartsco dot com. In fact, I have motors out in the shed from them. Is it a two speed fan?
DoubleR
PostPosted: Mon Apr 01, 2013 5:02 pm    Post subject: Re: tractor cab heater motor Reply to specific post Reply with quote
Is Cozy Cab still in business? If so, maybe they have one. I brought one from Curtis Cab a few years back for my after market Curtis Cab. Maybe there's will work in your cab. Although they are not very cordial people to deal with.
Hobo,NC
PostPosted: Mon Apr 01, 2013 5:24 pm    Post subject: Re: tractor cab heater motor Reply to specific post Reply with quote
Merle Brendeland wrote:
(quoted from post at 04:05:57 04/02/13) I have a Cozy Cab aftermarket cab which includes a wall mount heater with coolant in and out of the box. Rectanglular box with blade fan heater and around 4" depth. The motor needs replacement. No manufacturer name on motor. Have been to auto parts stores and no matching size.
Thanks
http://www.apairinc.com/iView.asp?Cat=Blower%20Motors&Scat=Blower%20Assemblies%20-%20Ag%20-%20Offroad
ben there
PostPosted: Mon Apr 01, 2013 7:24 pm    Post subject: Re: tractor cab heater motor Reply to specific post Reply with quote
Check with Grainger.com
JMS/.MN
PostPosted: Mon Apr 01, 2013 9:20 pm    Post subject: Re: tractor cab heater motor Reply to specific post Reply with quote
Cozy Cab is still in business.......Litchfield, MN. 1-320-693-3221. A division of Custom Products. 14 miles away from me- good luck on your search.
oldtanker
PostPosted: Mon Apr 01, 2013 9:35 pm    Post subject: Re: tractor cab heater motor Reply to specific post Reply with quote
Expensive! I looked for and found one through NAPA a couple of years ago. Talk about sticker shock! I solved that problem with a computer cooling fan. Largest size. They run on 12 volt! Cheap too!. Easy mod! I used zip ties to put it on the box heater and just wired it in. Worked good.
Rick
View user's profile Yahoo Messenger
Post new topic    Yesterday's Tractors Forum Index -> Tractor Talk All times are GMT - 8 Hours
