806 with injector line leak
jbraman
PostPosted: Tue Apr 30, 2013 5:47 pm    Post subject: 806 with injector line leak Reply to specific post Reply with quote
My 806 diesel with a 360 ih engine has a leak on the #1 cylinder right where it connects to the injector. The compression fitting seems to be loose. Can you replace just the fitting or do I need a whole new line?
Aces
PostPosted: Tue Apr 30, 2013 7:11 pm    Post subject: Re: 806 with injector line leak Reply to specific post Reply with quote
you need the line, make sure it is the same part number
pete 23
PostPosted: Wed May 01, 2013 9:27 am    Post subject: Re: 806 with injector line leak Reply to specific post Reply with quote
I have replaced few ferreles but they leave a deep groove in line usually so you have to cut a little off line. 250610R1 sleeve.
Aces
PostPosted: Wed May 01, 2013 6:25 pm    Post subject: Re: 806 with injector line leak Reply to specific post Reply with quote
If you cut the line off the fuel deliever is changed.
pete 23
PostPosted: Fri May 03, 2013 9:38 am    Post subject: Re: 806 with injector line leak Reply to specific post Reply with quote
You only need to cut about a 1/8th inch to move the ferrele to a new spot. Totally insifinicant.
