KING KUTTER FINISH MOWER PULLEY?
Muskellunge
PostPosted: Wed Jul 17, 2013 1:24 pm    Post subject: KING KUTTER FINISH MOWER PULLEY? Reply to specific post Reply with quote
I have a 5' KK finish mower about 10 yrs old. Both idler pulleys under the hinged gear box are shot. Do I remove the pulleys from the top of the deck, or from under the deck?
Is there a written procedure for KK pulley replacement anywhere?
Thank,
Muskie
JCinKY
PostPosted: Thu Jul 18, 2013 11:29 am    Post subject: Re: KING KUTTER FINISH MOWER PULLEY? Reply to specific post Reply with quote
Muskellunge wrote:
(quoted from post at 14:24:17 07/17/13) I have a 5' KK finish mower about 10 yrs old. Both idler pulleys under the hinged gear box are shot. Do I remove the pulleys from the top of the deck, or from under the deck?
Thank,
Muskie
On my 6' KK all you need to do is remove the rearmost two nuts from the gearbox plate and loosen the front two. This will let it swing up and forward.
The two idler pulley should be held on by two more lock nuts ON TOP OF THE DECK.
Just swing the gearbox out of the way and any lock nuts that remain on the idler pulleys.
Muskellunge
PostPosted: Thu Jul 18, 2013 1:50 pm    Post subject: Re: KING KUTTER FINISH MOWER PULLEY? Reply to specific post Reply with quote
Very good. Thanks for the info JC.
JCinKY
PostPosted: Fri Jul 19, 2013 3:46 am    Post subject: Re: KING KUTTER FINISH MOWER PULLEY? Reply to specific post Reply with quote
Muskellunge wrote:
(quoted from post at 14:50:23 07/18/13) Very good. Thanks for the info JC.
No problem.
Just don't honk down on those lock nuts when you re-install them so the idler can float. I had one too tight, and wore out the bearings in a spindle.
You kind of have to tighten and check to get it set right. Even tightening the nut for the gearbox plate can cause it to lock up.
Not too loose, not too tight.
