AUTOLITE MAX 4095 starters
chuck machinist
PostPosted: Mon Oct 14, 2013 5:21 pm    Post subject: AUTOLITE MAX 4095 starters Reply to specific post Reply with quote
Any leads on where I may find a 10 tooth starter assembly for a Autolite Max 4095 for my 411 ?
jstpa
PostPosted: Mon Oct 14, 2013 6:05 pm    Post subject: Re: AUTOLITE MAX 4095 starters Reply to specific post Reply with quote
That is a really common old drive . Any starter rebuilder will either have it or can get it. If you cant find one email me and I'll get you one. jstpa
chuck machinist
PostPosted: Tue Oct 15, 2013 1:13 pm    Post subject: Re: AUTOLITE MAX 4095 starters Reply to specific post Reply with quote
Thanks for the information on the starter, your right, it is still available and quite common. My rebuild will be drastically reduced.. the starter drive is roughly priced at $40.00.Thanks!
John Saeli
PostPosted: Tue Oct 15, 2013 5:02 pm    Post subject: Re: AUTOLITE MAX 4095 starters Reply to specific post Reply with quote
What did you decide on the nose cone?
chuck machinist
PostPosted: Tue Oct 15, 2013 5:14 pm    Post subject: Re: AUTOLITE MAX 4095 starters Reply to specific post Reply with quote
Ill have my hands on a starter carcass later this week John and then I will do a rebuild. At my leisure I will reweld the nose cone and save her for a spare. I will post some pics of the ring gear later in the week, when I get out to the farm. First glance does not look too worn .. I will take a small pry bar and rotate the entire ring gear for a good look!
John Saeli
PostPosted: Wed Oct 16, 2013 3:58 am    Post subject: Re: AUTOLITE MAX 4095 starters Reply to specific post Reply with quote
Usually, the ring gear will be burred in 3 areas. I've spent many hours on tractors & old trucks, reaching thru the starter hole w/ a file, filing burred teeth because I was too lazy to fix them correctly.
mEl
PostPosted: Wed Oct 16, 2013 4:13 pm    Post subject: Re: AUTOLITE MAX 4095 starters Reply to specific post Reply with quote
John Saeli wrote:
(quoted from post at 04:58:27 10/16/13) Usually, the ring gear will be burred in 3 areas. I've spent many hours on tractors & old trucks, reaching thru the starter hole w/ a file, filing burred teeth because I was too lazy to fix them correctly.
Check the armature for straight, when the nose breaks from broken gears often it tweaks the armature shaft some.
We welded a nose three times using stainless wire and a red preheat with a rosebud torch cooling it slowly. every time it broke it was at a different spot, the SS held perfectly.
I won't even tell you what DC engine we were trying to start!!!
