Thank You Dell - 12V Conversion Problems
Anonymous
Guest
PostPosted: Sun Jun 17, 2007 5:42 am    Post subject: Thank You Dell - 12V Conversion Problems Reply to specific post Reply with quote
Afeter I performed a 12V conversion on my '49 8N, it was always hard to start. I read in the archives that Dell suggested a 1/2 ohm 20W resistor. The conversion Kit (TISCO) said to wire the original balast resistor in series with the 1.2 ohm resistor supplied in the kit. These instruction are wrong and Dell is right. Anyone using the TISCO kit would be well advised to go to Radio Shack and buy a 1 ohm 10W resistor to put in parallel with the one supplied in the kit.
Dell (WA)
PostPosted: Sun Jun 17, 2007 7:09 am    Post subject: Re: Thank You Dell - yer welcome Reply to specific post Reply with quote
Glad it worked for you.......the embarrassed Dell
Anonymous
Guest
PostPosted: Sun Jun 17, 2007 9:33 am    Post subject: Re: Thank You Dell - 12V Conversion Problems Reply to specific post Reply with quote
[quote]Anyone using the TISCO kit would be well advised to go to Radio Shack and buy a 1 ohm 10W resistor to put in parallel with the one supplied in the kit.[/quote]
So you now have the OEM ballast & (2) 1 ohm's in Parallel or what ? If that is true your Fix didn't do much of anything (.2 amp increase in starting) and you are good for GO
Dell has always said to use "ONLY" the Parallel Resistors in the circuit. That is absolutly Wrong, for 2.5 ohm 12V Coil, and you will burn out your coil in time.
If you only have the Parallel Resistors in the Circuit, then you have another fault(resistance) in the ignition Circuit.
It is a fact that High Current results in easy Starting and LOW current ~2.2 amps will be hard starting. Most PLL would trouble shoot why the current is/was "THAT" low.
Your Tractor,
Marty 2n IL
PostPosted: Sun Jun 17, 2007 5:52 pm    Post subject: Re: Thank You Dell - 12V Conversion Problems Reply to specific post Reply with quote
I am not the electrial wizzards you guys are but the last one I did I used the orginal resistor just because there was no radio shack near me. It had a 12 volt coil already and hacked up wireing with no resistor so I started over when I was done I had 13.5 volts into the battery and 11.8 on the coil still running fine.
Anonymous
Guest
PostPosted: Mon Jun 18, 2007 3:10 am    Post subject: Re: Thank You Dell - 12V Conversion Problems Reply to specific post Reply with quote
[quote]I had 13.5 volts into the battery and 11.8 on the coil still running fine.[/quote]
Marty 2N IL,
If you used the OEM Ballast your likely OK because it's a PTC (Positive Temperature Coefficient) Resistor which means its resistance changes with current. Its designed to protect the coil by limiting @ 3 Amps.
Now your Voltage reading! Those I assume where taken with the tractor running. The Coil during operation has an inductive impedance that flips DC theory, that is when voltage is high (Max Inductive impedance) current, in the circuit, is at its lowest value (180 deg) It is when the Current reaches Max (minimum inductance) that voltage will be at its lowest value. It is this value that we need to know & a meter does not read minimum Voltage. That is why you require a scope to evaluate Operating (running) systems.
The Static DC measurement, with points closed, is the reading that you want. With a OEM ballast and 12v (2.5 ohm) coil you will measure ~ 8.0 Volts
Hope this Helps,
