Allis B Big end Rod bearings
Anonymous
Guest
PostPosted: Thu Jun 14, 2007 8:58 am    Post subject: Allis B Big end Rod bearings Reply to specific post Reply with quote
Can anyone point me in the direction of where i could get some big end rod bearings at 040 cus I having such trouble getting that particular size
Regards
Ben
George Andreasen
PostPosted: Thu Jun 14, 2007 9:50 am    Post subject: Re: Allis B Big end Rod bearings Reply to specific post Reply with quote
Try Tony Carbaugh in Turner, Oregon. He lists bearings in "all sizes". His ad can be found on the Unofficial Allis Website. He and Barb are nice to work with too.
ben phillips
PostPosted: Thu Jun 14, 2007 9:56 am    Post subject: Re: Allis B Big end Rod bearings Reply to specific post Reply with quote
Thank you very much i will get in touch with them
Regards
Ben
Dick L
PostPosted: Thu Jun 14, 2007 10:03 am    Post subject: Re: Allis B Big end Rod bearings Reply to specific post Reply with quote
I would tell you how I do it but the correct people would have a fit.
Ahh, let bashing start.
You can buy .030 and cut .005 shims to put under the inserts. The ends of the inserts have to then be filed as necessary and use plasti gage for a propper fit.
TxAllisMan
PostPosted: Thu Jun 14, 2007 10:27 am    Post subject: Re: Allis B Big end Rod bearings Reply to specific post Reply with quote
If you have a Napa auto parts close to you these guys can get you what your looking for. I use my Local Napa store and they get my parts for me.
Damon
N.E. Texas
CENTAUR
PostPosted: Thu Jun 14, 2007 11:26 am    Post subject: Re: Allis B Big end Rod bearings Reply to specific post Reply with quote
He can use (Prussian Blue) and a(three sided bearing scraper)to get a good fit.Done it myself,works fine and lasts a long time.CENTAUR
Dick L
PostPosted: Thu Jun 14, 2007 12:20 pm    Post subject: Ya But Reply to specific post Reply with quote
His rod journal is smaller that the .030 under bearing and NAPA or my other suppliers could not get the .040 under at the time. I needed to have a smaller hole than the .030 under standard so by slipping .005 under the top insert and .005 under the bottom insert My rod bearing hole was then .040 under standard, side to side. The ends of the bearing inserts held the hole to .050 top to bottom until the ends were filed to where when fitted over the crankshaft journal I had the .002 clearance I was after. The shim would need to be cut the same size as the insert to bring the sides in the .010
ben phillips
PostPosted: Thu Jun 14, 2007 12:38 pm    Post subject: Re: Ya But Reply to specific post Reply with quote
thanks for the comments i might resort to this method as it sounds feasable, and i am struggling with this
CENTAUR
PostPosted: Thu Jun 14, 2007 1:37 pm    Post subject: Re: Ya But Reply to specific post Reply with quote
You are 100% right.It was W.W.two surplus engines that I got to fit the cranks in after obtaining semi finished babbitted bearings.I did the same thing that you described on about a half dozen 6 cylinder chevys. CENTAUR
CENTAUR
PostPosted: Thu Jun 14, 2007 1:38 pm    Post subject: Re: Ya But Reply to specific post Reply with quote
El Toro
PostPosted: Fri Jun 15, 2007 5:00 am    Post subject: Re: Allis B Big end Rod bearings Reply to specific post Reply with quote
Your local auto machine shop may be able to get them. Hal
TxAllisMan
PostPosted: Sat Jun 16, 2007 10:25 pm    Post subject: Re: Allis B Big end Rod bearings Reply to specific post Reply with quote
I never had any trouble getting my bearings thriugh my local Napa dealer.
These guys have been in business in my town before i was even born and im 41 now.
I think it all comes down to parts stores that say they cant find things because they dont wont to.
The modern age of these things we peck on has almost made all prts guys lazy and they dont wont to open a book or pick up a telephone number to call a 1 800 number to their supplier to check on things.
I can remember looking up parts using micro fish while i worked for Big a Auto parts in the machine shop.
TxAllisMan
PostPosted: Mon Jun 18, 2007 4:12 pm    Post subject: Re: Allis B Big end Rod bearings Reply to specific post Reply with quote
http://www.agkits.com/index.asp?PageAction=VIEWPROD&ProdID=583
that link will get you the bearings you need.
Damon
N.E. Texas
