Generator/drive belt
peachhead
PostPosted: Wed Apr 22, 2015 8:33 pm    Post subject: Generator/drive belt Reply to specific post Reply with quote
Just wondering, how hard should it be to pull the belt tight when changing the generator on a 3000? I say that because tonight my tractor ran warm for the first time I can remember. I was dragging gravel, after dark I finally turned on the lights and noticed the temp gauge getting up towards red. I quit, parked, throttled down and let her cool off but before shutting down I took a look around to see anything out of the ordinary. I can't swear to it but it looked like the belt might be slipping. I do remember it was a lot easier than I thought it would be putting the gen back on so now I'm thinking it should have been a lot harder, and maybe I need a new belt. I was able to pull the generator all the way back and get the bolts in using both hands. I always remember having to use a pry bar when changing the alternator in any car or truck I've had.
I also remembered I haven't changed the oil in my air filter for a while, going to do that before I do anything else.
Forgot to clarify this is a 67 3000 diesel.
showcrop
PostPosted: Thu Apr 23, 2015 3:40 am    Post subject: Re: Generator/drive belt Reply to specific post Reply with quote
I have pretty much always used a tool to tension the belt. A loose belt is an occasional cause for overheating.
souNdguy
PostPosted: Thu Apr 23, 2015 9:18 am    Post subject: Re: Generator/drive belt Reply to specific post Reply with quote
Assuming the belt is the correct size and not burnt or chewed from slipping, re tension, and then press on the free span with a finger, I like
about 1/2" deflection at the mid point of the span. Too much and you are harder on bearings than needed, too little and you slip..
peachhead
PostPosted: Thu Apr 23, 2015 6:46 pm    Post subject: Re: Generator/drive belt Reply to specific post Reply with quote
That's kinda what I figured. I will check it again in the daylight tomorrow and see what I need to do. Thanks for the help!
I hope that turns out to be the problem, but like I said I need to clean the air filter anyway, and will take a look at the radiator fluid. I know it has not been changed in a long time.
peachhead
PostPosted: Fri Apr 24, 2015 7:05 pm    Post subject: Re: Generator/drive belt Reply to specific post Reply with quote
Just an update- the belt was not only stretched but was in the process of splitting and coming off the fan pulley altogether.
So started putting the belt on tonight, will finish tomorrow. Learned the hard way that it helps to go through the top after moving the battery tray (duh! moment), makes it a lot easier to get the belt on and off over the fan. I say off because I was trying to save the belt if I could just in case, it wasn't until I got it off that I realized it was splitting so badly.
Anyway that would definitely have been the problem. Got a new belt from Advance for $5.00 believe it or not, changed the oil in the air filter (which was still fairly clean) and did check the radiator. I need to get some antifreeze tomorrow, it needs filling but it doesn't smell bad so I think I am ok on that.
If I don't get stormed out I should be able to finish all this tomorrow and be back in business.
peachhead
PostPosted: Sat Apr 25, 2015 3:30 pm    Post subject: Re: Generator/drive belt Reply to specific post Reply with quote
Got the belt back on today and seems to be working fine. Also learned the hard way not to get your fingers behind the generator when you push it all the way forward. As my mama used to say, that smarted...
