8n finally running right again..thanks dell
Dell (WA)
PostPosted: Sat Aug 11, 2007 7:13 am    Post subject: Re: 8n finally running right again..thanks dell Reply to specific post Reply with quote
Hawk.........sometimes I'm a lucky guesser, thanks for follow up.......Dell
hawk36
PostPosted: Sat Aug 11, 2007 9:27 am    Post subject: 8n finally running right again..thanks dell Reply to specific post Reply with quote
well after a long pain in the you know what process of trying to figure it out i found problem. burnt the points up on it while back so i replaced them and rebuilt carb while i was at it. the dang thing cranked and ran fine on level ground but under a load would slowly die. alot suggested bad points so replaced again still same prob. i thought it was carb but it wasnt.several kept saying points and not enough fire but i checked plugs and wires and had fire so i was lost..............
finally it hit me just because i had fire doesnt mean it was strong enough fire so went to local store got a new $12 coil popped it in and wooooohooooooo man does she run like a champ.
i had forgot that you can burn up a coil even slightly when and if you burn up a set of points.
thanks everyone for the help esp. dell the old sparkie master kept saying it it finally sunk in lmao.
