Author |
Message |
RTR Tractor Expert
Posted: Fri Jun 10, 2016 11:14 am Post subject: Engine Serial Number Information |
Guys. I need to get the engine serial number from the "CA" in order to get the correct thermostat. Where can I find this information on my tractor/engine block?
THanks, |
Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 86972 Location: Lake of the Ozarks area of MO
Posted: Fri Jun 10, 2016 1:12 pm Post subject: Re: Engine Serial Number Information |
If I remember right it is just forward of the shiftier so if sitting on it if you slide you hand to the base of the shiftier and put your for finger straight out it should be close to touching it |
Back to top |
Aaron SEIA Tractor Expert
Posted: Fri Jun 10, 2016 2:42 pm Post subject: Re: Engine Serial Number Information |
That would be the tractor serial number by the shifter. Engine should be in the edge of the block by the bell housing.
AaronSEIA |
Back to top |
Posted: Sat Jun 11, 2016 3:43 am Post subject: Re: Engine Serial Number Information |
Checked the AGCO parts book. If you do NOT have a bypass housing, then you need t start 70220027. If you DO have a bypass housing, then you need 70226372. Bypass has a small hose going back to the block, no bypass is the single hose that goes back to the upper radiator.
AaronSEIA |
Back to top |
4wdtom Tractor Expert
Posted: Sun Jun 12, 2016 5:24 am Post subject: Re: Engine Serial Number Information |
Are you looking for more than the thermostat? There is a spring that holds it in the housing too. I
replaced a rusted one with part of the spring from an old grease gun. The housing is tall and the
thermostat needs to be held down near the engine with the spring as I remember it. Could be wrong,
but there is a spring in a B/C and I think a CA would be the same. |
Back to top |
RTR Tractor Expert
Posted: Sun Jun 12, 2016 10:24 am Post subject: Re: Engine Serial Number Information |
CVPost-4wdtom wrote: | (quoted from post at 18:24:28 06/12/16) Are you looking for more than the thermostat? There is a spring that holds it in the housing too. I
Mine has the small 2 inch long piece of hose going from the water pump to the thermostat housing. I'm guessing that is called a bypass hose?? When I removed the old thermostat there wasn't a spring but I guess it could have been long rusted away. |
Back to top |
Posted: Mon Jun 13, 2016 3:11 am Post subject: Re: Engine Serial Number Information |
http://agcopartsbooks.com/PartsBooksN/Viewer/book.aspx?book=agco/79001546
Go to the "cooling system-water manifold bypass" page and you can see a diagram. No spring i the picture. There is a spring in the non bypass manifold.
AaronSEIA |
Back to top |
RTR Tractor Expert
Posted: Mon Jun 13, 2016 4:17 am Post subject: Re: Engine Serial Number Information |
Aaron SEIA wrote: | (quoted from post at 16:11:36 06/13/16) http://agcopartsbooks.com/PartsBooksN/Viewer/book.aspx?book=agco/79001546
AaronSEIA |
Now you all see where my confusion is. |
Back to top |
