Mystery case tractor at auction
Jim Pollock
PostPosted: Wed Sep 13, 2017 4:13 am    Post subject: Mystery case tractor at auction Reply to specific post Reply with quote
I was at an auction last night and there was a case tractor there that looked real similar to my 210b except mine has individual gauges and this one had a gauge cluster. The hood was also different. It did have 6 bolt wheels like mine. It was not a com but it only had a 4 speed. Mine has a dual range shuttle. The model number tag was missing but it looked like it was originally on the left side of the dash. Mine is right below the gauges. Anyone know what model this might be?
It did have the industrial type front .axle
Case Nutty 1660
PostPosted: Wed Sep 13, 2017 7:02 am    Post subject: Re: Mystery case tractor at auction Reply to specific post Reply with quote
need more info, where was the battery at,, was the fuel tank part of the "hood" or under the hood,, could be a 430-530 or even a couple others
cnt
VACLee
PostPosted: Wed Sep 13, 2017 8:28 am    Post subject: Re: Mystery case tractor at auction Reply to specific post Reply with quote
With 6 lug wheels, gauge cluster and non com would only fit the description of a 310b. The sheet metal part of the dash would have been different from yours as to the way the hood joins it and there should have been a large removable panel to access the battery. Also the front edge of the fenders would have extended down to the floorboards.
Case Nutty 1660
PostPosted: Wed Sep 13, 2017 9:20 am    Post subject: Re: Mystery case tractor at auction Reply to specific post Reply with quote
I re read his post I thought he had said it did not have the cluster when he clearly said it did,, but early 30 series would also fit into the list as they also had the cluster so my comment is still on track as it can be several models besides the 310B like a 530 or 630 or a W-3 are three more, 430 would have the same hood as the 210 so we can almost rule that one out
cnt
VACLee
PostPosted: Wed Sep 13, 2017 12:10 pm    Post subject: Re: Mystery case tractor at auction Reply to specific post Reply with quote
What I was basing it on is the 6 lug wheels. 310, 210b, 310b, and 410b seem to be the only ones with 6. When the 430 came out it switched to 8 like the other larger ones. This is based on parts books and I know there are always exceptions and errors. Lee
Eagle Beagle
PostPosted: Wed Sep 13, 2017 3:40 pm    Post subject: Re: Mystery case tractor at auction Reply to specific post Reply with quote
Do you you remember if the radiator cap was visible or did it have a panel that sat flush with the hood. This differentiated the 1958 model year from the 1959 with the 59 radiator neck and cap sticking out above the hood on the 310b series.
Joe (Wa)
PostPosted: Wed Sep 13, 2017 4:16 pm    Post subject: Re: Mystery case tractor at auction Reply to specific post Reply with quote
1958 310B.
Joe (Wa)
PostPosted: Wed Sep 13, 2017 4:25 pm    Post subject: Re: Mystery case tractor at auction Reply to specific post Reply with quote
Parts manual 310B prior to serial 6128060 (1958- early 1959) had 6 lug rear wheels and after had 8 lug.
Joe
oldproudvet
PostPosted: Wed Sep 13, 2017 5:36 pm    Post subject: Re: Mystery case tractor at auction Reply to specific post Reply with quote
Identical to my 1959 310B #6125465. Mine has a hoe and a loader hung on it
Ande
PostPosted: Wed Sep 13, 2017 7:46 pm    Post subject: Re: Mystery case tractor at auction Reply to specific post Reply with quote
Here is mine before I brought her home
bradley martin
PostPosted: Thu Sep 14, 2017 1:20 am    Post subject: Re: Mystery case tractor at auction Reply to specific post Reply with quote
I have never seen a 430 with the gauge cluster, Tom. Did the very early ones use the gauge cluster and not indiviul guage?
Jim Pollock
PostPosted: Thu Sep 14, 2017 2:41 am    Post subject: Re: Mystery case tractor at auction Reply to specific post Reply with quote
It looked just like this picture. So I would say you are correct. It was probably a 310b. It was real rough but I thought about buying it for parts for my 210b. I know the guy who bought it and he bought it for parts. Would the rear axles from a 310b fit a 210b. My 210b has a backhoe and a loader and I have broke both rear axles in the past. I had a hard time finding replacement 6 bolt axles.
Jim Pollock
PostPosted: Thu Sep 14, 2017 2:46 am    Post subject: Re: Mystery case tractor at auction Reply to specific post Reply with quote
Fuel tank was not part of hood. It was just like my 210b. The battery was behind the fuel tank with a large removable cover. My 210b is similar but has a real small access hole for the battery. This one, the cover was as wide as the hood.
Case Nutty 1660
PostPosted: Thu Sep 14, 2017 3:01 am    Post subject: Re: Mystery case tractor at auction Reply to specific post Reply with quote
430's never had a cluster for sure, I missed he had said it had a cluster I was reading something that was not there, also was thinking of a 6 hole front wheel not the rears again thinking ahead of myself,, if I knew how to delete my comments from this page I would do so but sadly I do not sorry
