T340 Track roller lubricant?
T340
PostPosted: Thu Oct 19, 2017 6:50 am    Post subject: T340 Track roller lubricant? Reply to specific post Reply with quote
Still waiting on my owner's manual. Can someone that has one look to see what the recommended lube for the rollers(top & bottom) is?
Charlie
PostPosted: Thu Oct 19, 2017 5:44 pm    Post subject: Re: T340 Track roller lubricant? Reply to specific post Reply with quote
Lubriplate 5555. You also need a special tip to inject it properly into the rollers. I can give you more detail by email if needed.
T340
PostPosted: Fri Oct 20, 2017 7:07 am    Post subject: Re: T340 Track roller lubricant? Reply to specific post Reply with quote
Thanks. Got it.
T340
PostPosted: Mon Oct 30, 2017 6:33 am    Post subject: Re: T340 Track roller lubricant? Reply to specific post Reply with quote
After research I went with Super S, 00 spindle grease from Tractor Supply. The Lubriplate was not very available & costly..
I would like to know about the nozzle for application though. What's the O.D. & length?
jaluhn
PostPosted: Fri Nov 17, 2017 9:35 pm    Post subject: Re: T340 Track roller lubricant? Reply to specific post Reply with quote
My manual calls for multi-purpose gear lube -
"sulfur-phosphorous type gear lubricant meeting the requirements of IH spec B-22, grade 132H EP
or
Sulfur-chlorine-lead type gear lubricate meeting the requirements of IH spec B-22 grade 80H EP, 90H EP or 140H EP
or
Sulfur-chlorine-phosphorous gear lubricant meeting the requirements of milspec mil-l-2105b
It also states that gear lube meeting GL-4 spec must not be used unless they meet one of the above.
Interestingly, milspec l-2105B appears to cross to a GL-4 gear oil, so I'm not sure what to think.
It gives SAE-140 weight for above 32*, or 90 for 0-90* or 80w90 for -20 to +90*f.
Capacity is 3/4 pint for the front and track rollers and 1/2 pint for the top idler.
The insertion tool looks like a nozzle about 1/8 diameter and 3-4" long. I'll look at a torn apart idlers and see if I can get better dimensions tomorrow if I remember.
I personally would probably just put some gear oil of the heaviest grade you can find in and see how it works. Pretty much anything is likely better than nothing.
T340
PostPosted: Sat Nov 18, 2017 8:53 am    Post subject: Re: T340 Track roller lubricant? Reply to specific post Reply with quote
Thanks. Great info.
