Replacing these bolts on pressure plate
balsabones
PostPosted: Fri Nov 17, 2017 4:09 pm    Post subject: Replacing these bolts on pressure plate Reply to specific post Reply with quote
I need to find the technical name for the adjustable bolts, that press on the throw out bearing. There are 3 of them, 1 on each arm. I want to search the web to see if I can buy replacements. My tractor is a TAFE 35di, 1996. John Deere D was kind enough to help me diagnose and find the reason my PTO quit working. The drive hub had sneered off of the PTO disk. The factory had left the 3 slave bolts in the pressure plate after install. The main disc and PTO disc still look hardly worn and the false fly wheels are not burned or worn. I want to replace the disc, throw out bearing and pilot bearing. To replace the whole pressure plate assembly is almost $400 compared to less than $100. I will try to post picture of what I need. Thanks to everyone for a great forum.
Bob
PostPosted: Fri Nov 17, 2017 6:20 pm    Post subject: Re: Replacing these bolts on pressure plate Reply to specific post Reply with quote
A GOOGLE search for "clutch finger bolts" turned up over 2,000,000 possibilites.
I presume they are metric?
There's a "clutch and brake and industrial friction" place a couple hours from me and I've gotten America clutch finger bolts from them, but I've never asked about metric.
Any place like that near you/in the Yellow Pages?
balsabones
PostPosted: Fri Nov 17, 2017 6:52 pm    Post subject: Re: Replacing these bolts on pressure plate Reply to specific post Reply with quote
Thank you Bob for the reply. I will do a little searching and see if I can find similar place near me. I'm about 20 miles west of Augusta Ga, in McCormick SC. I will remove one the bolts and see if it's metric or standard. If I can't find a place near me, would you be willing to share the phone # of the place up your way. Maybe they will ship if they have what I need.
Thank you so much
Dieseltech
PostPosted: Sun Nov 19, 2017 6:44 pm    Post subject: Re: Replacing these bolts on pressure plate Reply to specific post Reply with quote
Looks like the common MF clutch lever bolt the 65 and newer tractors used..
hd6gtom
PostPosted: Sun Nov 19, 2017 8:22 pm    Post subject: Re: Replacing these bolts on pressure plate Reply to specific post Reply with quote
Go to the unofficial allis forum and look up Rick Corder. He rebuilds those, probably has them laying around
balsabones
PostPosted: Mon Nov 20, 2017 9:19 am    Post subject: Re: Replacing these bolts on pressure plate Reply to specific post Reply with quote
I measured one of them and not counting the bolt head, (they are worn down), they are 13/16 long and 3/8 in diameter. The thread count is 24 TPI, standard US thread pitch.
John Deere D
PostPosted: Tue Nov 21, 2017 9:28 am    Post subject: Re: Replacing these bolts on pressure plate Reply to specific post Reply with quote
Info as per MF service Manual & Parts Book:
Post new topic    Yesterday's Tractors Forum Index -> Lesser Known Classics All times are GMT - 8 Hours
