Author |
Message |
Brendon Warren Tractor Guru
Posted: Wed Jan 03, 2018 9:57 am Post subject: Re: New Home Made Tool |
I think a sursingle (sp) would work. You know the metal end from the strap that goes around the cow when using a Surge milking machine. |
Back to top |
big tee Tractor Expert
Posted: Wed Jan 03, 2018 10:37 am Post subject: Re: New Home Made Tool |
Looks like a bull cinch to me---Tee |
Back to top |
TimV Tractor Guru
Posted: Wed Jan 03, 2018 1:33 pm Post subject: Re: New Home Made Tool |
They certainly do, as that's exactly what we used at home. For those unaware, the link shows what a surcingle is--the metal part called the "triangle" is what we used--the strap had broken so we had it lying around. Bent a bigger hook in the end and used it for years. If memory serves, we bent it so it would lie flat when the triangle was pushed and pulled under the log--I think ACG is going to find his hook digs in and grabs on every root, rock, and other obstacle he encounters, but it still should beat doing it by hand.
surcingle
Back to top |
Dusty MI Tractor Expert
Joined: 17 Dec 2000 Posts: 2169 Location: Lansing MI. area
Posted: Wed Jan 03, 2018 2:59 pm Post subject: Re: New Home Made Tool |
CVPost-47fivewindow wrote: | (quoted from post at 18:03:22 01/02/1 Zipper puller upper? |
For Paul Bynian ? |
Back to top |
gab Tractor Guru
Posted: Wed Jan 03, 2018 3:16 pm Post subject: Re: New Home Made Tool |
You're right. |
Back to top |
Adirondack case guy Tractor Guru
Posted: Wed Jan 03, 2018 3:39 pm Post subject: Re: New Home Made Tool |
I forgot about them. Yes very similar. They didn't have the T handle though, just a Z shaped end to lock into the eye of the strap. We had the Delavel sp. milkers which sat in the manger under the cows.
Loren |
Back to top |
Posted: Wed Jan 03, 2018 3:46 pm Post subject: Re: New Home Made Tool |
Tim, I will tell you how it works next summer. I debated on which side off the bow to put the finger on. Figured when hooked,the choker would keep it from digging into the dirt.
Time will tell.
Loren |
Back to top |
TimV Tractor Guru
Posted: Wed Jan 03, 2018 4:09 pm Post subject: Re: New Home Made Tool |
Any commercially-made one I've seen (attached link is just the first one I found, but they're all pretty much identical) has the hook bent flat, not at a 90-degree angle, but by all means give it a shot--it's not that big a job to redo if it doesn't work.
Logging Choker Grab Rod
Back to top |
allenlane Regular
Posted: Thu Jan 04, 2018 12:34 pm Post subject: Re: New Home Made Tool |
Nice job Loren! Thanks for sharing. |
Back to top |
