Pump house
JimS
PostPosted: Wed Jan 03, 2018 12:03 pm    Post subject: Pump house Reply to specific post Reply with quote
Our pump house burned in the Nuns Fire here in Sonoma County. I need to construct a new one. For obvious reason, I am rather
turned off by wood construction (the old building construction). It is a small building, 6x6 on an existing concrete slab. I
would like to construct it out of metal and I would like to have at least one wall and the roof easily removable to be able to
service the well without destroying the structure. What type of construction would you employ and how would you build it. It
needs to be reasonably economical. We seldom have weather below 30 degrees F. 20 is the coldest I've seen here. Thank you.
old
PostPosted: Wed Jan 03, 2018 12:17 pm    Post subject: Re: Pump house Reply to specific post Reply with quote
If it where me I would do it with rock and concrete that way a fire is a whole lot less likely to take it away again. While metal will not burn it will melt and In a fire I have seen metal building fall faster then a wood building does and well a rock on will stand even in a fire
Mike M
PostPosted: Wed Jan 03, 2018 12:34 pm    Post subject: Re: Pump house Reply to specific post Reply with quote
Home depot lowes etc. sell metal studs and pole building siding/roofing. You could use that and screw it all together. It would come apart easy.
kevinj54
PostPosted: Wed Jan 03, 2018 12:48 pm    Post subject: Re: Pump house Reply to specific post Reply with quote
Pre cast concrete should work
Steve@Advance
PostPosted: Wed Jan 03, 2018 1:01 pm    Post subject: Re: Pump house Reply to specific post Reply with quote
Are there any metal building suppliers near you?
Most are customer friendly, will work with you on design.
They have worked out the most economical system of construction, yet provide a durable product.
There are Youtube videos of metal building construction. If you familiarize yourself with the concepts, look at available components online, then go to the showroom, ask questions, get quotes.
They can provide weld up, or bolt together framework. Sounds like you would want bolt together for ease of access.
Janicholson
PostPosted: Wed Jan 03, 2018 1:10 pm    Post subject: Re: Pump house Reply to specific post Reply with quote
Buy a concrete manhole Set it on the foundation and put a manhole cover on the top. Jim
The quick answer
Adirondack case guy
PostPosted: Wed Jan 03, 2018 3:13 pm    Post subject: Re: Pump house Reply to specific post Reply with quote
Janicholson---Perfect solution. Fast cheap and easy.
showcrop
PostPosted: Wed Jan 03, 2018 4:25 pm    Post subject: Re: Pump house Reply to specific post Reply with quote
Does this building house just a pump? Or does it also cover the well? What type of well? dug or drilled? what type of pump? jet or submersible? Does it also house a bladder tank? How big?
showcrop
PostPosted: Wed Jan 03, 2018 4:34 pm    Post subject: Re: Pump house Reply to specific post Reply with quote
Post new topic    Yesterday's Tractors Forum Index -> Tractor Talk All times are GMT - 8 Hours
