Ford flat head v8
jd35b
PostPosted: Tue Jan 02, 2018 4:08 pm    Post subject: Ford flat head v8 Reply to specific post Reply with quote
What head makes cooler temp middle discharge or front discharge for coolant or does it matter
russ1
PostPosted: Thu Jan 04, 2018 1:12 pm    Post subject: Re: Ford flat head v8 Reply to specific post Reply with quote
The flathead fords have two water pumps that move a lot of water. To make it run cooler you need thermostats to slow don the flow to allow time in the radiator to cool. position of the outlets on the heads have no effect.
DMartin9N-2N
PostPosted: Wed May 02, 2018 5:47 pm    Post subject: Re: Ford flat head v8 Reply to specific post Reply with quote
Hi:
I have heard that a thermostat will slow the flow, but that does not matter. If the water is going through the radiator "fast", it is also going through the engine "fast", so nothing is gained or lost by slowing down the water flow rate.
Think about it like this: If the engine runs for an hour, then water has been picking up heat from the engine for an hour, and giving off heat in the radiator for an hour. All the water is moving the same speed, so makes no difference.
Dennis M. in W. Tenn.
Post new topic    Yesterday's Tractors Forum Index -> Yesterday's Trucks All times are GMT - 8 Hours
