screwdriver test
tntractor
PostPosted: Thu Jan 11, 2018 9:39 pm    Post subject: screwdriver test Reply to specific post Reply with quote
If a 1600 has been sitting for a while, should I do the screwdriver test before trying to
start it? Also, will one of those engines go into a 77?
oliverkid
PostPosted: Thu Jan 11, 2018 11:23 pm    Post subject: Re: screwdriver test Reply to specific post Reply with quote
1600 is a rosa master pump not a Bosch. Completely different animal so there is no screwdriver test.
NYOlivers
PostPosted: Fri Jan 12, 2018 2:56 am    Post subject: Re: screwdriver test Reply to specific post Reply with quote
I would make sure you have good clean fuel to all the filters and at the injection pump. Prime fuel system with hand pump on lift pump. A good battery, check oil and should be good.
Olliejunkie
PostPosted: Fri Jan 12, 2018 6:57 am    Post subject: Re: screwdriver test Reply to specific post Reply with quote
Roosa pumps can stick too. I don't know how to check them. I don't know if they run away but I would be ready to shut the air off.
rrman61
PostPosted: Fri Jan 12, 2018 7:36 am    Post subject: Re: screwdriver test Reply to specific post Reply with quote
How about a 1650?
Tramway Guy
PostPosted: Fri Jan 12, 2018 7:45 am    Post subject: Re: screwdriver test Reply to specific post Reply with quote
There is a ?screwdriver test? only on American Bosch PSB pumps. Not Roosa Master or any in-line pumps. Those Vosch pumps were used on all 66, 77, 88 and 99 (6-cylinder) as well as Super variants of all those (except for a trial run of very few Super 77s with the Roosa Master) Super 55, and the 3-digit models through about 1961 or so, maybe later. None of the 4-digit tractors had Bosch pumps from the factory.
Dieseltech
PostPosted: Fri Jan 12, 2018 8:23 am    Post subject: Re: screwdriver test Reply to specific post Reply with quote
It's Stanadyne/Roosa on both early indirect and late direct injected diesels. Pumps and injectors are different though.
NYOlivers
PostPosted: Fri Jan 12, 2018 12:11 pm    Post subject: Re: screwdriver test Reply to specific post Reply with quote
Hey Dieseltech: can you explain the "screwdriver test" for people who don't know what it is? Also what should be done to Bosch pumps if they do sit for awhile and what can be done to prevent them from sticking? I know its a little off the original thread, but it did get brought up so I though it would be a time for a refresher. Thanks
Dieseltech
PostPosted: Fri Jan 12, 2018 1:54 pm    Post subject: Re: screwdriver test Reply to specific post Reply with quote
It's some times helpful on the American Bosch PSB pumps, after removing the fuel control unit and using a small pick or screwdriver to see if the plunger metering sleeve will move up/down freely. Most are stuck after setting awhile, and when the plunger is stuck just turning the engine with stuck internal parts wrecks the pump. Even a free metering sleeve does not mean the plunger is free too though.
