730 gas miss
johndeeregreg
PostPosted: Thu Jan 11, 2018 10:37 pm    Post subject: 730 gas miss Reply to specific post Reply with quote
our 730 will miss on 2, if i pull the plug wire out of the distributor cap and hold it against the cap right at the to where wire goes in it will shoot the spark up to the wire and fire, i can then put wire back down like its suppose to be and it will keep firing but drops that side when a load is applied. what should i check first? i haven't spent any time checking condition of wire end or cap but cap has been replaced in the last year and a half and the wires aren't that old either. has pertronix electronic ignition and coil, copper wires, and autolite 3116 plugs. i have been told that carbon core plug wires should be used with the pertronix systems but i'm not sure why.
JD Seller
PostPosted: Thu Jan 11, 2018 10:54 pm    Post subject: Re: 730 gas miss Reply to specific post Reply with quote
You need to change the plug wires to resistant wires. You going to ruin your Solid state ignition if you don't. The resistant wires make there be more voltage at the spark plug. Your holding the wire away from the plug is doing the same thing and that is why it starts firing then.
I would recommend using the wires that your ignition system recommends.
ET
PostPosted: Fri Jan 12, 2018 4:18 am    Post subject: Re: 730 gas miss Reply to specific post Reply with quote
If you switch cylinders with the spark plug does the problem follow the plug or stay with the cylinder? I could just be a bad plug.
D-
PostPosted: Fri Jan 12, 2018 5:57 am    Post subject: Re: 730 gas miss Reply to specific post Reply with quote
Missing under load is usually plugs, even though they look good.
Try switching sides with them.
johndeeregreg
PostPosted: Fri Jan 12, 2018 6:30 am    Post subject: Re: 730 gas miss Reply to specific post Reply with quote
ok, ill check plugs and get the right wires.
620rookie
PostPosted: Sat Jan 13, 2018 6:18 am    Post subject: Re: 730 gas miss Reply to specific post Reply with quote
I have a 1952 60 that I tractor pull with. One of the first things I did when I purchased it was put petronics Electronics in it. I also put in stainless steel plug wires at that time. It runs great, has never missed a beat since then. That was four years ago. I've also been able to increase the spark plug gap to 0.0050 with increased power output.
David G
PostPosted: Sat Jan 13, 2018 7:02 am    Post subject: Re: 730 gas miss Reply to specific post Reply with quote
IMHO, missing under load can be anything on the secondary ignition, as load increases the compression pressures which increase the voltage required to jump the plug gap This means cap, rotor, wires and plugs are all suspect, I would not narrow it down to plugs.
Pete in MD
PostPosted: Sat Jan 13, 2018 7:40 am    Post subject: Re: 730 gas miss Reply to specific post Reply with quote
You mean 0.050
ET
PostPosted: Sat Jan 13, 2018 8:05 am    Post subject: Re: 730 gas miss Reply to specific post Reply with quote
Plugs are very easy to check first before you start spending money.
620rookie
PostPosted: Sat Jan 13, 2018 9:02 am    Post subject: Re: 730 gas miss Reply to specific post Reply with quote
Yes thanks
JD Seller
PostPosted: Sat Jan 13, 2018 9:58 pm    Post subject: Re: 730 gas miss Reply to specific post Reply with quote
By widening the plug gap your making the voltage go up there.
