Ford 5000 Super Major
Goto page 1, 2, 3, 4, 5, 6  Next
gandl2123
PostPosted: Sun Jan 28, 2018 4:39 pm    Post subject: Ford 5000 Super Major Reply to specific post Reply with quote
I'm going to try to post some pictures of what I have here I've had this tractor fall in my lap I really like to know more about it and what it is and maybe how much it's worth. I'm told it is not ran for the last two or three years but it's supposed to run good. It is located in Augusta Georgia USA.
cdmn
PostPosted: Sun Jan 28, 2018 6:47 pm    Post subject: Re: Ford 5000 Super Major Reply to specific post Reply with quote
It's of 1964 vintage. A good general purpose tractor in its day.
It's kind of hard to gamble on a tractor that doesn't run.
You could part it out for $500 or more depending how fast you want
it gone. To get it running, you need at least $500 in tires and
a good cleaning of fluids, such as draining the bottom pint or so of
water condensation in engine and drive line. Sometimes the injector pump
gets sticky. If you know what you're doing it's not too hard to get it
freed up. I've got one with many, many hours, but it starts easily.
brownsmule
PostPosted: Sun Jan 28, 2018 7:15 pm    Post subject: Re: Ford 5000 Super Major Reply to specific post Reply with quote
some interest IF you decide to part out or sell whole. email open pwb
gandl2123
PostPosted: Mon Jan 29, 2018 10:57 am    Post subject: Re: Ford 5000 Super Major Reply to specific post Reply with quote
Went today and checked it out very well it all looks together the oil in the engine seems to be black I guess I could drain and make sure there's no water in it before I do it. From what I gather it used to have a dozer type blade on it I can't tell how many hours it's got on it because the gauge is messed up there. It does have probably a $500 or more 6 foot box blade on the back. When you say vintage apparently vintage doesn't make it worth anymore correct. We were able to turn the fan over and the motor is not locked it moved over quite easily and the first thing we noticed is some diesel fuel leaking out of the injector front area. So I imagine if I hook up the starter with the battery imagine I'm going to have one heck of a leak there a fuel smells very funny in the tank. I also believe it's been switched over to 12 volt as I see some of the wires are cut and it has what looks like a GM alternator on it. I'm going to go ahead and post some more pictures that I took today. I think I can get the owner to sell it to me for $500 and a couple rides on my nice Harley. Not sure if I'm doing the right thing here as I don't let anybody ride my Harley both tires need to be fixed because there's riveted patches in the tops of each tire.
gandl2123
PostPosted: Mon Jan 29, 2018 11:06 am    Post subject: Re: Ford 5000 Super Major Reply to specific post Reply with quote
gandl2123
PostPosted: Mon Jan 29, 2018 12:12 pm    Post subject: Re: Ford 5000 Super Major Reply to specific post Reply with quote
gandl2123 wrote:
(quoted from post at 12:06:52 01/29/18)
DAF-3 Dossier by ARPS parts available. Evidence of former hydrolics.
cdmn
PostPosted: Mon Jan 29, 2018 2:02 pm    Post subject: Re: Ford 5000 Super Major Reply to specific post Reply with quote
I didn't know about the blade. Add for that. The last time, I bought a pair of tires,
they were nearly $1,000 installed.[Imports]. A little diesel seepage shouldn't bother at this point. Can probably be fixed with a new gasket or adhesive. I don't know what a southern climate does, but I wouldn't think 3 year old diesel fuel would be "bad'.
My use of "Vintage" in this context is just an expression, meaning approximate. It was the last year for English Fordson tractors. They made more of them under a different name in Spain. In the area of old cars, Vintage is something like 1919-1930. I don't know if tractor guys go by that very much. And they aren't like "Vintage Wine", in that certain years are better than others, but some might be thought so. For example, the Ford 3000, or JD 4020, or Farmall M. Some may think of 1942-45 tractors as "War Vintage", since they had special features to reduce use of strategic materials.
JLMac
PostPosted: Mon Jan 29, 2018 4:29 pm    Post subject: Re: Ford 5000 Super Major Reply to specific post Reply with quote
Great pictures, nice find! Make sure you change the oil in the injection pump, it takes same oil as engine as do the air breathers.
gandl2123
PostPosted: Mon Jan 29, 2018 8:21 pm    Post subject: Re: Ford 5000 Super Major Reply to specific post Reply with quote
JLMac wrote:
(quoted from post at 17:29:59 01/29/18) Great pictures, nice find! Make sure you change the oil in the injection pump, it takes same oil as engine as do the air breathers.
Thanks for the good advice. I wasn't even aware that it had oil to be changed in it. Lol
JLMac
PostPosted: Tue Jan 30, 2018 5:15 pm    Post subject: Re: Ford 5000 Super Major Reply to specific post Reply with quote
Your welcome, the front blade attachment would be some what collectible I would think. Is the blade kicking around there?
gandl2123
PostPosted: Tue Jan 30, 2018 5:46 pm    Post subject: Re: Ford 5000 Super Major Reply to specific post Reply with quote
JLMac wrote:
(quoted from post at 18:15:21 01/30/18) Your welcome, the front blade attachment would be some what collectible I would think. Is the blade kicking around there?
No I can't find the blade anywhere it seems like all the support mechanisms are underneath the tractor but anything that went to the blade is gone and there seems to be some hydraulics in the back that are no longer there as well
brownsmule
PostPosted: Fri Feb 09, 2018 3:29 pm    Post subject: Re: Ford 5000 Super Major Reply to specific post Reply with quote
Any update on this old tractor? Thanks pwb
knares
PostPosted: Fri Feb 09, 2018 4:50 pm    Post subject: Re: Ford 5000 Super Major Reply to specific post Reply with quote
if that Blade is the same as mine, its not a front blade, it fits underneath between the front and rear axles
The tractor looks the same as mine but where the 5000 came from ???
gandl2123
PostPosted: Fri Feb 09, 2018 5:39 pm    Post subject: Re: Ford 5000 Super Major Reply to specific post Reply with quote
Would you please send me some pictures of your tractor also I would like if you could to explain to me what some of the controls are on the left and right side and as you're sitting in the seat there are so many Libras and bars I have no idea. Also I want to start this tractor but I have no key and I'm not sure how to start it without a key. It looks as though somebody has put an alternator on this tractor and switch it over to 12 volt from its original 6 volt. That too is a little bit confusing.
gandl2123
PostPosted: Fri Feb 09, 2018 5:42 pm    Post subject: Re: Ford 5000 Super Major Reply to specific post Reply with quote
I wish somebody could tell me where the Ford 5000 came from from what I have discovered it seems as though this tractor was imported from Britain and it was right before Ford came out with their Ford 5000 so at least came off the boat Ford just put their sticker on them and sold. That's the story I'm getting I wish I could tell.
Post new topic    Yesterday's Tractors Forum Index -> Fordson All times are GMT - 8 Hours
Page 1 of 6
