Implement Attachment
Goto page Previous  1, 2
old
PostPosted: Sun Feb 11, 2018 12:55 pm    Post subject: Re: Implement Attachment Reply to specific post Reply with quote
Draft control is thing built into many tractor with 3 point that when a plow or other such machine gets into a hard pull the draft control will left up on the plow automatically so as to keep form getting the tractor stuck etc.
SVcummins
PostPosted: Sun Feb 11, 2018 5:53 pm    Post subject: Re: Implement Attachment Reply to specific post Reply with quote
My guess is that most of the modern implements are sized for
hobby farmers and food plot farmers and use on larger gardens in
which cases a fully mounted implment is a lot handier to use and
manuver in such small areas and also cost as you mentioned
DeltaRed
PostPosted: Sun Feb 11, 2018 6:32 pm    Post subject: Re: Implement Attachment Reply to specific post Reply with quote
depends on the hitch I guess....I put the 3 point on the SuperM in about '81/'82. It has pulled a 3 bottom rollover plow,carried a 6 row mounted cornplanter,carryed a full rack of wts to hold the front down.The hitch itself has never broken,but I have had to reinforce the mounts a couple of times. Broke the clamps around the axle.
fastfarmall
PostPosted: Sun Feb 11, 2018 6:50 pm    Post subject: Re: Implement Attachment Reply to specific post Reply with quote
If you can buy a Allis Chalmers, Or a IHC, 12 0r 14 disk, you can cut them down pretty easy, cut the frame and narrow them down to half of it was originally,including the rock shaft for the wheels, and you got 6 OR 7 FT disk, and you got spare for almost ever!
Traditional Farmer
PostPosted: Mon Feb 12, 2018 3:09 am    Post subject: Re: Implement Attachment Reply to specific post Reply with quote
Many of the aftermarket hitches are built as strong or stronger than original hitches and work just as good or better.That said some people can and will tear up anything they use no sense
using the tractor and try to do things far beyond what they size tractor or implement is suited for.And if the hitch doesn't get broken something else will.
old
PostPosted: Mon Feb 12, 2018 3:52 pm    Post subject: Re: Implement Attachment Reply to specific post Reply with quote
On many of he aftermarket 3 points I have seen they also hook up in some way to the draw bar or draw bar mounts so the lower arms do in fact pull pretty much in the same area as the draw bar. Also a draw bar is made to handle large pull type loads but not heavy down ward loads. Most pull equipment puts very little weight on the draw bar but a lot of drag pull weight
Page 2 of 2
