Using epoxy metal
Goto page Previous  1, 2
Texasmark1
PostPosted: Mon Feb 12, 2018 4:27 pm    Post subject: Re: Using epoxy metal Reply to specific post Reply with quote
JB Weld is popular here. Ensure you mix it 50-50 and give it plenty of time to cure out. Grind it off, drill and tap and be on your way. for holes, or finish off with an end mill.
Janicholson
PostPosted: Mon Feb 12, 2018 7:21 pm    Post subject: Re: Using epoxy metal Reply to specific post Reply with quote
Well Implied. Jim
Dick L
PostPosted: Tue Feb 13, 2018 4:58 am    Post subject: Re: Using epoxy metal Reply to specific post Reply with quote
Because I was wanting to use the product on an injection mold they sent in a tec fellow. He helped with the repair and it only lasted a week. I machined the cured product with a standard mill cutter and finished up with fine sand strip.
circus
PostPosted: Tue Feb 13, 2018 8:51 am    Post subject: Re: Using epoxy metal Reply to specific post Reply with quote
Maybe a autobody aluminized polyester filler would work. Metal-to-metal or all-metal comes to mind. As long as you don't use it on a high temperature bearing it should work. Sets in 10 minutes. Surfaces must be clean,oil free and scuffed.
fixerupper
PostPosted: Tue Feb 13, 2018 5:12 pm    Post subject: Re: Using epoxy metal Reply to specific post Reply with quote
I used JB weld to fit a new bushing in a walleyed out bore where the front axle pivots on a 1086 IH. Several thousand hours later I replaced the bushing again just to tighten things up. The old JB ‘d bushing was holding just fine. When I pounded it out I had forgotten I had used JB the first time and I wondered what that gray stuff was till the light bulb lit up in my head.
Page 2 of 2
