Ford 8n trans-mix axle bracket
rtj1972
PostPosted: Mon Apr 16, 2018 7:30 am    Post subject: Ford 8n trans-mix axle bracket Reply to specific post Reply with quote
I need to build the axle brackets for a trans-mix cement mixer to fit a 8n and I
need the dimension and hole spacing. I was hoping that someone could help me.
HCooke
PostPosted: Mon Apr 16, 2018 1:59 pm    Post subject: Re: Ford 8n trans-mix axle bracket Reply to specific post Reply with quote
Might try the other forum. Someone there, maybe Jim(Utah) used to have one.
Nebraska Cowboy
PostPosted: Mon Apr 16, 2018 2:16 pm    Post subject: Re: Ford 8n trans-mix axle bracket Reply to specific post Reply with quote
CVPost-rtj1972 wrote:
(quoted from post at 16:30:52 04/16/1Cool I need to build the axle brackets for a trans-mix cement mixer to fit a 8n and I
What can I help you with? I own one and would be glad to help you out. Not at my shop now however, will be tomorrow morning.
rtj1972
PostPosted: Mon Apr 16, 2018 6:02 pm    Post subject: Re: Ford 8n trans-mix axle bracket Reply to specific post Reply with quote
I need the measurements of the hole
locations and the overall size of the
bracket
Tim PloughNman Daley
PostPosted: Tue Apr 17, 2018 1:41 am    Post subject: Re: Ford 8n trans-mix axle bracket Reply to specific post Reply with quote
There are three documents on the NTC site, under MANUALS/MISC, including the original owner/operator/setup manual. Jim(UT) has been absent for a few years now as he has gotten out of the tractor business so he doesn't post there anymore. The documents are in pdf and you can download them for free. There is a fella about 55 miles from me who has a 9N with a Trans-Mix mounted. It is parked outside his HD construction business. I once left a note on it asking if he wanted to sell just the mixer and he called me and said no, he still uses it. If you get stumped, I could stop and measure it but no plans to get that way anytime soon. My email is open if you want to save it in case...
Tim *PloughNman* Daley(MI)
Bob
PostPosted: Tue Apr 17, 2018 4:40 am    Post subject: Re: Ford 8n trans-mix axle bracket Reply to specific post Reply with quote
Knowing what the distance is between the fender bolt holes you should be able to "scale" the parts in the photos and get awful darned close.
Hobo,NC
PostPosted: Tue Apr 17, 2018 8:23 am    Post subject: Re: Ford 8n trans-mix axle bracket Reply to specific post Reply with quote
Bolt hole center 4.825
rtj1972
PostPosted: Tue Apr 17, 2018 9:10 am    Post subject: Re: Ford 8n trans-mix axle bracket Reply to specific post Reply with quote
I want to thank all of you for your help, I think I have the built.
Nebraska Cowboy
PostPosted: Tue Apr 17, 2018 12:13 pm    Post subject: Re: Ford 8n trans-mix axle bracket Reply to specific post Reply with quote
Angle iron bracket is 14 inches long and is 2 & 1/2 inches by 2 & 1/2 inches by 1/4 inch thick. 1 side has a 2 inch notch cut out of it and has the one hole that is 1 inch center from the end
Tall T
PostPosted: Tue Apr 17, 2018 8:55 pm    Post subject: Re: Ford 8n trans-mix axle bracket Reply to specific post Reply with quote
Looks like 1.25" to the center of the hole all right. Smile
rtj1972
PostPosted: Wed Apr 18, 2018 3:46 am    Post subject: Re: Ford 8n trans-mix axle bracket Reply to specific post Reply with quote
Thank you, just what I needed.
