electronic ignition
pa don
PostPosted: Fri May 25, 2018 5:16 pm    Post subject: electronic ignition Reply to specific post Reply with quote
bought a 302 it runs fine until it gets up to operating temp. then it startes missing running on one or two cylinders let it cool a little start it up runs till hot it electronic ignition can they act this way or whats the problem
rvirgil_KS
PostPosted: Fri May 25, 2018 5:33 pm    Post subject: Re: electronic ignition Reply to specific post Reply with quote
Do you have a direct 12 volt coil (no external resistor required) or do you have a 6volt or 12 volt external resistor required coil?
If the latter, do you have the resistor in the circuit.
Is the EI wired correctly
IanC
PostPosted: Fri May 25, 2018 6:57 pm    Post subject: Re: electronic ignition Reply to specific post Reply with quote
The electronic ignition units are very sensitive to the ohm rating of the coil. The so called electronic ignitions are really just a Hall Effect no moving parts trigger for a conventional coil, not a true electronic ignition like an MSD box. I always told customers that if they wanted the P*******x unit to work the best get their coil also.
Heath72
PostPosted: Sat May 26, 2018 9:35 pm    Post subject: Re: electronic ignition Reply to specific post Reply with quote
One thing that not many people know is that you need to throw those copper core wires away when you switch to electronic ignition and put the carbon core wires on instead. Learned the hard way on a U that I converted a few years ago. I was told that the copper provides too much resistance. Like someone else said, a hot coil doesn't hurt either.
Bob
PostPosted: Sat May 26, 2018 10:32 pm    Post subject: Re: electronic ignition Reply to specific post Reply with quote
CVPost-Heath72 wrote:
(quoted from post at 00:35:51 05/27/1Cool One thing that not many people know is that you need to throw those copper core wires away when you switch to electronic ignition and put the carbon core wires on instead. Learned the hard way on a U that I converted a few years ago. I was told that the copper provides too much resistance. Like someone else said, a hot coil doesn't hurt either.
" I was told that the copper provides too much resistance."
Must have been quite a BS'er that told you that "old mechanics' wives tale"!
Electronic noise suppression is the issue, and spiral wound "magnetic core" wires will do that job more reliably than "carbon core" wires.
Dieselbear
PostPosted: Sun May 27, 2018 6:45 am    Post subject: Re: electronic ignition Reply to specific post Reply with quote
try a new condenser first
pa don
PostPosted: Sun May 27, 2018 11:08 am    Post subject: Re: electronic ignition Reply to specific post Reply with quote
thanks guys it was the coil like the song I was looking for fix in all the wrong places
