wfe swap from model 50 to a model 60
marlin54
PostPosted: Wed Oct 03, 2018 6:55 pm    Post subject: wfe swap from model 50 to a model 60 Reply to specific post Reply with quote
I would like to know if a wfe off a JD 60 will swap to a JD 50 ?
mdross
PostPosted: Thu Oct 04, 2018 3:27 am    Post subject: Re: wfe swap from model 50 to a model 60 Reply to specific post Reply with quote
Quite sure it will, look up under tractor around steering pedestal and see if there are four unused bolt holes?
buickanddeere
PostPosted: Thu Oct 04, 2018 3:29 am    Post subject: Re: wfe swap from model 50 to a model 60 Reply to specific post Reply with quote
CVPost-marlin54 wrote:
(quoted from post at 22:55:43 10/03/1Cool I would like to know if a wfe off a JD 60 will swap to a JD 50 ?
Most guys would swap thier wife for a 60.
2520-4010
PostPosted: Thu Oct 04, 2018 4:05 am    Post subject: Re: wfe swap from model 50 to a model 60 Reply to specific post Reply with quote
I'd rather have a "40".......
I "saw" the same thing....lol.
James Howell
PostPosted: Thu Oct 04, 2018 4:26 am    Post subject: Re: wfe swap from model 50 to a model 60 Reply to specific post Reply with quote
Yes.
Take a look at the FRONT AXLE HOUSING ASSEMBLY diagram below.
Note the housing(Key 11) AF 1182 R and AB 4045 R.
Note the housing(Key 13) AF 1182 R and AB 4045 R.
Hope this helps.
PJH
PostPosted: Thu Oct 04, 2018 7:19 am    Post subject: Re: wfe swap from model 50 to a model 60 Reply to specific post Reply with quote
Some 50's don't have a convertible pedestal, but I'll bet you know that already. Mine would be a big job to convert because I'd have to change the pedestal too.
Jon Erickson
PostPosted: Thu Oct 04, 2018 5:28 pm    Post subject: Re: wfe swap from model 50 to a model 60 Reply to specific post Reply with quote
You can have my John Deere 50 and your choice of two of three nice 520's if you take my wife with the tractors.
marlin54
PostPosted: Thu Oct 04, 2018 6:00 pm    Post subject: Re: wfe swap from model 50 to a model 60 Reply to specific post Reply with quote
No I dont think I know what a covertible pedestal is ..I have had farmall pedestals off and on but not a deere .and there seems to be 2 of the holes ,on the mounting plate that someone has made larger for some reason. that's what makes me believe it was on something else than the 60 model .
PJH
PostPosted: Fri Oct 05, 2018 5:31 am    Post subject: Re: wfe swap from model 50 to a model 60 Reply to specific post Reply with quote
The convertible pedestal is a two piece unit that allows you to remove the lower portion and leave the part under the sheet metal in place. My 50 is an early model, and it has the one piece pedestal. If yours is a convertible pedestal, it will have four large bolts visible below the grill - these bolts hold the lower portion in place.
SVcummins
PostPosted: Wed Oct 10, 2018 9:39 pm    Post subject: Re: wfe swap from model 50 to a model 60 Reply to specific post Reply with quote
I read wife swap to.
buickanddeere
PostPosted: Thu Oct 11, 2018 5:47 am    Post subject: Re: wfe swap from model 50 to a model 60 Reply to specific post Reply with quote
CVPost-SVcummins wrote:
(quoted from post at 01:39:23 10/11/1Cool I read wife swap to.
I seen wfe but thought it would make a good joke .
SVcummins
PostPosted: Thu Oct 11, 2018 7:47 am    Post subject: Re: wfe swap from model 50 to a model 60 Reply to specific post Reply with quote
It was funny
