Allis Chalmers G creeper gear failure
neilpoulson
PostPosted: Sat Oct 27, 2018 12:01 pm    Post subject: Allis Chalmers G creeper gear failure Reply to specific post Reply with quote
Three times I have lost my creeper gear. Each time I found that the shifter rod had moved past the neutral position. I then took the tractor apart and realigned the shifter to regain the use of the creeper gear. Does anyone know why this happens and what I can do to fix it?
Thanks to anyone for your help
Neil
JoeM(GA)
PostPosted: Sat Oct 27, 2018 12:11 pm    Post subject: Re: Allis Chalmers G creeper gear failure Reply to specific post Reply with quote
Usually a worn shift lever end and/or the mating notch on the shift rail is worn.
Mike(NEOhio)
PostPosted: Sat Oct 27, 2018 2:51 pm    Post subject: Re: Allis Chalmers G creeper gear failure Reply to specific post Reply with quote
It's a little tricky to keep those two keys in place while you insert the shift lever. Are you sure one isn't dropping out? If OK then it's just wear.
Dick L
PostPosted: Sun Oct 28, 2018 5:51 am    Post subject: Re: Allis Chalmers G creeper gear failure Reply to specific post Reply with quote
What keys are you talking about? I don't recall any keys.
JoeM(GA)
PostPosted: Sun Oct 28, 2018 1:11 pm    Post subject: Re: Allis Chalmers G creeper gear failure Reply to specific post Reply with quote
Dick, I think he's referring to the lever guide pins.
Dick L
PostPosted: Sun Oct 28, 2018 1:49 pm    Post subject: Re: Allis Chalmers G creeper gear failure Reply to specific post Reply with quote
I'll never find out as I will never pull one down again. I just don't recall any loose pins in the five or six I had pulled all apart and put back together. I still have several transmissions in the shed.
Mike(NEOhio)
PostPosted: Sun Oct 28, 2018 6:42 pm    Post subject: Re: Allis Chalmers G creeper gear failure Reply to specific post Reply with quote
Been a while since I had mine apart so I'm going by my not so great memory. Actually a pin with a squared head on it. Had to do it when the wife tried driving it and somehow got it in two gears. Never figured out how she did it but I haven't had it happen since.
Hubschy
PostPosted: Sun Nov 04, 2018 2:28 pm    Post subject: Re: Allis Chalmers G creeper gear failure Reply to specific post Reply with quote
Are you using a "g" transmission, or a "b" transmission? The b a/c transmissions are not bored for the keepers that are required to keep the shift lever on a "g" from wobbling and jumping out of the shifter slot. I do not see the keepers, or keys, I your picture. They are a must have for the G tractor.
neilpoulson
PostPosted: Mon Nov 05, 2018 7:18 am    Post subject: Re: Allis Chalmers G creeper gear failure Reply to specific post Reply with quote
It is a g transmission with guide pins installed. I'm not sure what picture you refer to as I didn't post any. A g transmission would also need to be drilled for the creeper shifter rod.
Hubschy
PostPosted: Mon Nov 05, 2018 8:33 am    Post subject: Re: Allis Chalmers G creeper gear failure Reply to specific post Reply with quote
Ah, someone else posted the picture above. You are right about boring the shift lever hole and the keeper holes too on a B transmission. I'll agree with JoeM's assessment in that case.
