MHF 202 Power Steering / Speedy Sleeve Question
Goto page Previous  1, 2
BIG1RED9
PostPosted: Thu Nov 08, 2018 11:44 am    Post subject: Re: MHF 202 Power Steering / Speedy Sleeve Question Reply to specific post Reply with quote
No. I was going to have the machinist figure it out from the seal.. however it will cost more for him to fix it than a new part (not surprised).
So for me I need to think about the drilling of the housing and tapping in a fitting to reduce the pressure and then either use a new shaft or put on a sleeve to repair to my current shaft.
I can tell you that the seal is a tight fit on the sleeve.
Caryc
PostPosted: Thu Nov 08, 2018 11:52 am    Post subject: Re: MHF 202 Power Steering / Speedy Sleeve Question Reply to specific post Reply with quote
BIG1RED9 wrote:
(quoted from post at 12:44:48 11/08/1Cool
Is a new shaft even available?
Inno
PostPosted: Thu Nov 08, 2018 2:34 pm    Post subject: Re: MHF 202 Power Steering / Speedy Sleeve Question Reply to specific post Reply with quote
Yes, the shaft is available as a complete assembly with the worm screw etc. but it's a bit on the expensive side. I replaced one in my 202 and broke it quickly which is what made me decide to get power steering working.
Caryc
PostPosted: Thu Nov 08, 2018 3:21 pm    Post subject: Re: MHF 202 Power Steering / Speedy Sleeve Question Reply to specific post Reply with quote
Inno wrote:
(quoted from post at 15:34:09 11/08/1Cool Yes, the shaft is available as a complete assembly with the worm screw etc. but it's a bit on the expensive side. I replaced one in my 202 and broke it quickly which is what made me decide to get power steering working.
I saw the shaft here on YT's site for around $160. That doesn't sound so expensive to me. Is that the one you are referring to.
Inno
PostPosted: Fri Nov 09, 2018 11:56 am    Post subject: Re: MHF 202 Power Steering / Speedy Sleeve Question Reply to specific post Reply with quote
It might be. Seems to me I paid more for it. There are a couple of different ones depending on if it has power steering or not.
Caryc
PostPosted: Fri Nov 09, 2018 12:30 pm    Post subject: Re: MHF 202 Power Steering / Speedy Sleeve Question Reply to specific post Reply with quote
Inno wrote:
(quoted from post at 12:56:53 11/09/1Cool It might be. Seems to me I paid more for it. There are a couple of different ones depending on if it has power steering or not.
That one I looked at on YT is for power steering.
Inno
PostPosted: Fri Nov 09, 2018 2:31 pm    Post subject: Re: MHF 202 Power Steering / Speedy Sleeve Question Reply to specific post Reply with quote
Maybe it just seemed expensive to me at the time.The last few months have been so costly around here that $160 is a pittance!
Caryc
PostPosted: Fri Nov 09, 2018 2:46 pm    Post subject: Re: MHF 202 Power Steering / Speedy Sleeve Question Reply to specific post Reply with quote
Inno wrote:
(quoted from post at 15:31:09 11/09/1Cool Maybe it just seemed expensive to me at the time.The last few months have been so costly around here that $160 is a pittance!
Granted, it is a good hit to any working mans wallet.
BIG1RED9
PostPosted: Fri Nov 09, 2018 5:07 pm    Post subject: Re: MHF 202 Power Steering / Speedy Sleeve Question Reply to specific post Reply with quote
I would plan on $50 to $100 for seals and such and its involved. The whole steering assembly needs to come apart.
Its the way I am going and am planning several days for frustration breaks.
Don
Caryc
PostPosted: Fri Nov 09, 2018 6:25 pm    Post subject: Re: MHF 202 Power Steering / Speedy Sleeve Question Reply to specific post Reply with quote
BIG1RED9 wrote:
(quoted from post at 18:07:17 11/09/1Cool
Don
Yeah, that break down drawing in the parts book kind of scares me a little. Shocked
I'm hoping once I get in there again, I will find that the speedy sleeve came loose. If it did, I will use JB Weld on it this time.
BIG1RED9
PostPosted: Fri Nov 09, 2018 6:36 pm    Post subject: Re: MHF 202 Power Steering / Speedy Sleeve Question Reply to specific post Reply with quote
Was so close to going that route. Took a day of arguing with myself about it to go the replacement route. I had to pull the assembly to clean out the trans so some of the work was underway. Mine is a real mess.
ptfarmer
PostPosted: Fri Nov 09, 2018 8:36 pm    Post subject: Re: MHF 202 Power Steering / Speedy Sleeve Question Reply to specific post Reply with quote
I have yet to see one of these steering boxes that wasn't a real mess!
Page 2 of 2
