44 or 44 special?
toot
PostPosted: Mon Nov 12, 2018 1:11 pm    Post subject: 44 or 44 special? Reply to specific post Reply with quote
Tractor serial tag is missing. New to these
tractors. Is this a staight 44 or a
special?
toot
PostPosted: Mon Nov 12, 2018 1:12 pm    Post subject: Re: 44 or 44 special? Reply to specific post Reply with quote
Hold on trying to get photos
marloweg
PostPosted: Mon Nov 12, 2018 2:12 pm    Post subject: Re: 44 or 44 special? Reply to specific post Reply with quote
best way to tell is engine size 4 cyl. 6 cyl. flat head or valve in head cast wheels or pressed steel on latter ones a 44 will have a 260 ci. and the special will have a 277 ci engine you can find that on the block at the head line on the right side on the flat spot above the generator
Dieseltech
PostPosted: Mon Nov 12, 2018 3:35 pm    Post subject: Re: 44 or 44 special? Reply to specific post Reply with quote
The 44 Special came with cast wheel centers front and rear, friction hand throttle next to the steering wheel, larger brake and clutch pedals, larger hydraulic cylinder if fitted with "follow up" linkage quadrant. If gas, should be the 277 engine, dad's diesel was still the 260. Most had three point and the PTO live hand clutch too. Since the tag is gone, look near the PTO shift lever, the number is also stamped on top of the transmission case along the edge.
44Wheatland
PostPosted: Mon Nov 12, 2018 3:48 pm    Post subject: Re: 44 or 44 special? Reply to specific post Reply with quote
A 44 Special also has a heavier frame.
centash
PostPosted: Mon Nov 12, 2018 6:03 pm    Post subject: Re: 44 or 44 special? Reply to specific post Reply with quote
And a wider front axle, wider rear rims and a different cast centre for the 30 inch wheels.
Ben
