Engine mount stripped
JohnMatic
PostPosted: Fri Nov 16, 2018 7:36 pm    Post subject: Engine mount stripped Reply to specific post Reply with quote
One step forward... Well I have finally finished my engine rebuild but I've hit a snag. One of the engine mounts has stripped. So my question is how important is this? Can I fill with JB Weld or do I need to remove engine and put in some type of helicoil?
Photo attached. Thanks, John
Steve@Advance
PostPosted: Fri Nov 16, 2018 9:06 pm    Post subject: Re: Engine mount stripped Reply to specific post Reply with quote
Any chance there are some threads left deeper in the hole?
If so, you can bottom out a stud with some Locktite, put a nut on the stud.
But as many blots as that has, one stripped won't make any difference.
Mike Groom
PostPosted: Sat Nov 17, 2018 7:04 am    Post subject: Re: Engine mount stripped Reply to specific post Reply with quote
If Steve's stud idea doesn't suit you it looks like the bolts are either 3/8 or 7/16,I would drill and tap it to the next size larger and call it good.I have tore
down several tractors that had just that done to them.
MCOHIO
PostPosted: Sat Nov 17, 2018 7:08 am    Post subject: Re: Engine mount stripped Reply to specific post Reply with quote
I had a 48 TE that had the same problem with 4 being stripped. I used thread repair inserts- not Heli-coil. I used the tractor for several years after that with no issues. A Heli-coil may very well be strong enough as well but I would not trust any epoxy to repair the threads.
