Allis B Oil
allisbchal
PostPosted: Sat Nov 17, 2018 7:33 pm    Post subject: Allis B Oil Reply to specific post Reply with quote
Hi folks,
Got a 1951 B that likes to leak oil when it gets hot. Don't have the problem when its cool, obviously because the oil is a little thicker cold. Going to replace the seals eventually, but for time being, what oil would you recommend to run to keep it from leaking as much?
Would 20W-50 work or would something else be better?
Thanks!
old
PostPosted: Sun Nov 18, 2018 8:17 am    Post subject: Re: Allis B Oil Reply to specific post Reply with quote
I run 20W-50 oil in just about every thing I have and I have a lot of tractors. Only 2 I do not run it in is the 1935 JD-B that burns oil and I use a 60W oil in it and the one diesel tractor I have I use Rotella oil in it and it is a 10W-40. I have 5 plus A/C tractors and all of them use the 20W-50
Butch(OH)
PostPosted: Mon Nov 19, 2018 3:53 am    Post subject: Re: Allis B Oil Reply to specific post Reply with quote
The difference in leakage between what should be in it and 20W-50 will be trivial but if you are convinced differently go ahead and try it, it will only cost you the price difference between 30W and 20W-50.
allisbchal
PostPosted: Mon Nov 19, 2018 4:36 am    Post subject: Re: Allis B Oil Reply to specific post Reply with quote
CVPost-Butch(OH) wrote:
(quoted from post at 04:53:13 11/19/1Cool The difference in leakage between what should be in it and 20W-50 will be trivial but if you are convinced differently go ahead and try it, it will only cost you the price difference between 30W and 20W-50.
Anything else you’d recommend besides the 20w-50 then?
Butch(OH)
PostPosted: Mon Nov 19, 2018 4:55 am    Post subject: Re: Allis B Oil Reply to specific post Reply with quote
You mean as in bottle fixes? I have never personally seen a bottled remedy for a leak. Thicker oil will slow leaks a little bit in places where the oil doesn't get very warm. However when oils are warmed up to engine temps there is not enough difference in viscosity to make much difference. As I said it costs you virtually nothing to try thicker oil but dont expect the difference to be dramatic.
My recommendation? next rainy Saturday put it inside and fix it. Its a short day's work to pull the engine, replace both crank seals along with pan and timing cover gaskets and put it all back together ready to go to work
D beatty
PostPosted: Mon Nov 19, 2018 5:07 am    Post subject: Re: Allis B Oil Reply to specific post Reply with quote
There are two products that are good at stopping engine leaks and mix with any type of engine oil. I have used Lucas engine
oil stop leak and works. The other is Blue Devil engine oil stop leak which I have never used. Both products may take a few
hours to several days of engine use before leak stops.
D beatty
PostPosted: Mon Nov 19, 2018 7:44 am    Post subject: Re: Allis B Oil Reply to specific post Reply with quote
I have used Lucas on a 20 year old truck that mains were leaking and used Lucas and after second oil change they stopped leaking. Also had the GMC 4x4 that the rear ends were seeping at the carrier bearing and Lucas oil stabilizer stop them and that's been 10 years ago.
old
PostPosted: Mon Nov 19, 2018 8:14 am    Post subject: Re: Allis B Oil Reply to specific post Reply with quote
I used some of that oil stop leak stuff years ago on a car I had. I'll NEVER use it again because doing so cost me a lot of $$ due to the fact the stop leak stopped up the oil pressure relief valve in the oil pump and it would blow oil filter gaskets so the pan had to be dropped and the oil pump replaced.
chaskaduo
PostPosted: Mon Nov 19, 2018 8:17 am    Post subject: Re: Allis B Oil Reply to specific post Reply with quote
I have found that those oil leak fix additives usually don't work on cork, leather, and half the time paper gaskets. There made to swell rubbers and plastics I've read. Your experience may vary.
D beatty
PostPosted: Mon Nov 19, 2018 2:55 pm    Post subject: Re: Allis B Oil Reply to specific post Reply with quote
That' strange because the lucas oil stop leak does not make oil heavier or make the oil sticky. I would say you had more going on with that engine. I have used it in old engines that were well maintained with no problems.
old
PostPosted: Tue Nov 20, 2018 7:12 am    Post subject: Re: Allis B Oil Reply to specific post Reply with quote
This was in a 1971 Chevy Vega and it had oil changes every 3000 miles all it life but at around 100,000 miles it started using so much oil I tried the stuff to stop leaks and it stopped up the oil pressure relief valve so I'll NEVER trust the stuff again
Ted in NE-OH
PostPosted: Tue Nov 20, 2018 12:58 pm    Post subject: Re: Allis B Oil Reply to specific post Reply with quote
Adding a few quarts of 10W-30 now and then as needed is cheap until you can fix it right. Valve covers are chronic leakers on the B. I
attach the valve cover gasket to the valve cover with Permatex #1 and let it set a few days before installing. Clean valve cover with a
degreaser first. Do not use gasket cement between gasket and engine head. Good luck
