Tractor ford 1310 was running stalled out now wont start.
Goto page 1, 2  Next
Charlie moore
PostPosted: Sun Dec 23, 2018 4:44 pm    Post subject: Tractor ford 1310 was running stalled out now wont start. Reply to specific post Reply with quote
Ran out of fuel, put in more, started up ran for about 20 minutes, quit running. I pulled injectors had them test, failed. Replaced with new ones. Bled everything out, several times. Still wont start. Light gray smoke, was very black before. Any help would be appreciated.
Bob
PostPosted: Sun Dec 23, 2018 10:21 pm    Post subject: Re: Tractor ford 1310 was running stalled out now wont start Reply to specific post Reply with quote
ASSUMING you didn't add "bad fuel" (with water in it, for example), either you haven't got all the air bleed out of the fuel system, or you stirred up debris in the tank that has clogged something.
OR, it could have possibly just been NEARLY out of fuel and stopped due to some mechanical failure that happened at that moment.
If it doesn't start after a thorough bleeding (did you loosen fittings at the injectors and crank it 'til fuel came out) (keep body parts away from high-pressure fuel), or you don't get fuel at the injectors, the next thing to do would be to verify that the internals of the pump are rotating with the engine and are "in time".
showcrop
PostPosted: Mon Dec 24, 2018 5:21 am    Post subject: Re: Tractor ford 1310 was running stalled out now wont start Reply to specific post Reply with quote
Did you have fuel pushing out at the loosened injector lines before you condemned and pulled those poor old injectors?
Traditional Farmer
PostPosted: Mon Dec 24, 2018 5:25 am    Post subject: Re: Tractor ford 1310 was running stalled out now wont start Reply to specific post Reply with quote
Do the simple and easy stuff first like making sure there is a full flow of good fuel coming out of the tank,then the line to the first filters,etc.Replacing the injectors which obviously were not the original problem is the last thing you'd need to do.
Dieseltech
PostPosted: Mon Dec 24, 2018 6:33 am    Post subject: Re: Tractor ford 1310 was running stalled out now wont start Reply to specific post Reply with quote
Those SMALL diesels don't move much fuel at full load, so bleeding will take MUCH longer. What I do on small glow plug diesels is remove all the plugs so engine will crank easier and faster. With the lines loose at all injectors crank engine with throttle at 1/3 or more, when there's fuel at each injector tighten the line nuts. Now crank more until you see air/fuel mist blow out each glow plug hole, when you see that you can install the plugs and engine will start. While the plugs are out I test them on a charger and make sure the tip heats up as it should, if not replace any bad plugs.
Adirondack case guy
PostPosted: Mon Dec 24, 2018 7:18 am    Post subject: Re: Tractor ford 1310 was running stalled out now wont start Reply to specific post Reply with quote
Are you sure the glow plugs are working???
Charlie moore
PostPosted: Mon Dec 24, 2018 10:39 am    Post subject: Re: Tractor ford 1310 was running stalled out now wont start Reply to specific post Reply with quote
CVPost-Adirondack case gu wrote:
(quoted from post at 08:18:54 12/24/1Cool Are you sure the glow plugs are working???
I have not yet tested the glow plugs. How would I do that
Charlie moore
PostPosted: Mon Dec 24, 2018 10:46 am    Post subject: Re: Tractor ford 1310 was running stalled out now wont start Reply to specific post Reply with quote
I bled out from the filter to the injectors. There was good flow( my first diesel) from what a couple other guys said. Spit fuel a few inches from the coupler. I cranked it over after new injectors were installed but before attached, seamed like plenty of fuel coming out. I've bled it 4 times
Charlie moore
PostPosted: Mon Dec 24, 2018 10:48 am    Post subject: Re: Tractor ford 1310 was running stalled out now wont start Reply to specific post Reply with quote
Yes I did. It was huffing black smoke. When I brought the injectors to be tested. They said the fuel was just blowing through
Bob
PostPosted: Mon Dec 24, 2018 12:19 pm    Post subject: Re: Tractor ford 1310 was running stalled out now wont start Reply to specific post Reply with quote
Charlie moore wrote:
(quoted from post at 13:48:18 12/24/1Cool
Conventional wisdom, if all injectors were like that, the first thing would be to wonder if it's been massively overheated?
Charlie moore
PostPosted: Mon Dec 24, 2018 12:24 pm    Post subject: Re: Tractor ford 1310 was running stalled out now wont start Reply to specific post Reply with quote
CVPost-Traditional Farmer wrote:
(quoted from post at 06:25:58 12/24/1Cool Do the simple and easy stuff first like making sure there is a full flow of good fuel coming out of the tank,then the line to the first filters,etc.Replacing the injectors which obviously were not the original problem is the last thing you'd need to do.
The shop did say the injectors we not functioning properly. Gravity fed fuel to the pump. Spits pretty good when cranking.
Charlie moore
PostPosted: Mon Dec 24, 2018 12:26 pm    Post subject: Re: Tractor ford 1310 was running stalled out now wont start Reply to specific post Reply with quote
Very good, I'll try that method of removing glow plugs wait for the mist to blow out. Thank you
Charlie moore
PostPosted: Mon Dec 24, 2018 12:28 pm    Post subject: Re: Tractor ford 1310 was running stalled out now wont start Reply to specific post Reply with quote
I'm not sure, how would I test them? Thank you
Charlie moore
PostPosted: Mon Dec 24, 2018 12:34 pm    Post subject: Re: Tractor ford 1310 was running stalled out now wont start Reply to specific post Reply with quote
I've had the tractor for 3 months, everything was going fine, until it ran out of fuel. It always started with a lot of black smoke but cleared up within a minute. Plenty of coolant in radiator.
David G
PostPosted: Mon Dec 24, 2018 12:36 pm    Post subject: Re: Tractor ford 1310 was running stalled out now wont start Reply to specific post Reply with quote
Quit running does not really sound like bad injectors, more like a bad pump or other issue, would think bad injectors would just not run right or hard to start.
Goto page 1, 2  Next
Page 1 of 2
