D-14 power steering
georgejo4050
PostPosted: Mon Dec 31, 2018 8:47 am    Post subject: D-14 power steering Reply to specific post Reply with quote
I have a 1957 D-14 and when I run it, the motor oil will end up in the power steering, I have disassembled figuring to find the nose on the power steering pump broken or cracked to allow the motor to in, but it all looks ok, I have not pulled the gear off, is there a shaft seal that could go bad allowing this to happen? This seemed to have started after an engine overhaul.
Any help would be appreciated
George
DrAllis
PostPosted: Mon Dec 31, 2018 9:00 am    Post subject: Re: D-14 power steering Reply to specific post Reply with quote
Are you 1000% sure it is sucking motor oil out of the engine?? I'd be more inclined to think you are sucking air into the power steering pump which swells up the oil in the steering reservoir and makes it vomit out steering oil that is foamy. Yes, there is a shaft seal on the steering pump, but removing the pump for an engine OH shouldn't have done anything to that seal. It is more likely your suction hose is damaged or clamps not tight causing the problem I described.
Mr.Ferguson
PostPosted: Mon Dec 31, 2018 11:58 am    Post subject: Re: D-14 power steering Reply to specific post Reply with quote
Well at least your pump works, when I got mine I discovered that the pump had been damaged beyond repair. And it has been fun trying to find one
DrAllis
PostPosted: Mon Dec 31, 2018 2:53 pm    Post subject: Re: D-14 power steering Reply to specific post Reply with quote
What is the issue with your PS pump?? I've always been able to repair them unless there aren't parts available from AGCO any more.
Mr.Ferguson
PostPosted: Mon Dec 31, 2018 10:11 pm    Post subject: Re: D-14 power steering Reply to specific post Reply with quote
A tooth came off the cylinder, and went through the pump, most likely multiple times
DrAllis
PostPosted: Tue Jan 01, 2019 5:06 am    Post subject: Re: D-14 power steering Reply to specific post Reply with quote
And, you have been unable to find a complete power steering pump in a salvage yard ??
georgejo4050
PostPosted: Wed Jan 02, 2019 7:50 am    Post subject: Re: D-14 power steering Reply to specific post Reply with quote
When the oil starts coming out the vent on the steering unit it is black and not foamy. all my lines are steel and flared on the end and were tight when I took it back apart.
This has got me stumped.
georgejo4050
PostPosted: Wed Jan 02, 2019 11:24 am    Post subject: Re: D-14 power steering Reply to specific post Reply with quote
DrPosted: Wed Jan 02, 2019 7:50 am Post subject: Re: D-14 power steering
This has got me stumped.Allis wrote:
(reply to post at 10:00:58 12/31/1Cool
