1850 Brake Replacement
eye4iron
PostPosted: Fri Jan 04, 2019 5:15 pm    Post subject: 1850 Brake Replacement Reply to specific post Reply with quote
I am going to buy some brake discs for my 1850. Is there anything
else I should buy before I start taking it apart?
Is there anything unusual I should watch for when I have it apart?
rrlund
PostPosted: Sat Jan 05, 2019 6:38 am    Post subject: Re: 1850 Brake Replacement Reply to specific post Reply with quote
When you get in there,if there's any oil in there at all,replace the seals on the pinion shaft. Best way to get them out if you have to is drill two small holes in them,put screws in them,wrap a wire around the screws and pull them that way. When you get the actuators out,unhook the springs and split them in half and make sure those balls are clean as a whistle. Be sure all the pivot points on those actuators work free and easy.
2-stroke DD
PostPosted: Sat Jan 05, 2019 7:03 am    Post subject: Re: 1850 Brake Replacement Reply to specific post Reply with quote
Like rrlund said check for oil and not only clean everything but also replace those 3 springs on each side. Do not use any oil or grease to lubricate anything. If you have dry graphite you can use that to lube the balls. If you have a later model with the shims to adjust the brakes make sure you have all of them to put back in
IanC
PostPosted: Sat Jan 05, 2019 12:56 pm    Post subject: Re: 1850 Brake Replacement Reply to specific post Reply with quote
I would install new balls and springs in the discs. They may not look bad, but for as little as they cost they should be replaced. Taking the discs apart will also allow you to inspect the ramps for wear.
eye4iron
PostPosted: Sun Jan 06, 2019 10:50 am    Post subject: Re: 1850 Brake Replacement Reply to specific post Reply with quote
Thanks for the info. I will order the seal, springs and balls also.
gary66
PostPosted: Tue Jan 08, 2019 8:56 pm    Post subject: Re: 1850 Brake Replacement Reply to specific post Reply with quote
if taking them apart doesn't say using anti seize would've been good I'l say it. use it on reassembly.
