Doubt I can get this BGS-H Cletrac running...
Goto page Previous  1, 2, 3
mopardude318
PostPosted: Tue Dec 18, 2018 8:24 am    Post subject: Re: Doubt I can get this BGS-H Cletrac running... Reply to specific post Reply with quote
Of course there were some stuck bolts in the exhaust manifold, so I made a repair that has worked excellent for me in the past.
Cut the bolts off flat:
Drilled the holes to accept a 1/2-20 tap:
Then I buy these brass fittings which have a 1/2-20 straight thread, and Loctite them in:
Then I drill and tap the inside of the fitting for a 3/8-16 bolt:
Then grind off the heads and make sure its all flat:
Works very good Smile
Cut off a piece of stainless, I'm gonna straight pipe it!
Then I painted the manifold with POR 15 manifold paint and baked it in the oven, which my wife wasn't happy about that at all. Sad(
scootergmc
PostPosted: Tue Dec 18, 2018 8:42 am    Post subject: Re: Doubt I can get this BGS-H Cletrac running... Reply to specific post Reply with quote
Neat stuff. You know there's a difference between "get this... running" and restoration???? Ha Ha.... Looks great.
Pro tip on the oven baking: Find a free used commercial oven on Craigslist and keep it in garage for such purposes. Happy wife...
something or other...
mopardude318
PostPosted: Wed Dec 19, 2018 9:26 am    Post subject: Re: Doubt I can get this BGS-H Cletrac running... Reply to specific post Reply with quote
scootergmc wrote:
(quoted from post at 09:42:44 12/18/1Cool
Sure turning into a resto! I think I found a free oven on Craigslist. Smile
Today was an excellent day though. I finished lapping the valves, my father is helping me here.
I replaced 2 valve guides and 2 exhaust valves.
We got everything cleaned up and finished the valve adjustment:
Bolted on the head:
And exhaust manifold:
We got it started! Man it sounds really good! I don't want to run it too long without coolant, but I'll post a video soon! I need to finish the radiator and install new freeze plugs, but I have to remove the water pump and the starter, a couple freeze plugs sit right under there.[/QUOTE]
scootergmc
PostPosted: Wed Dec 19, 2018 10:31 am    Post subject: Re: Doubt I can get this BGS-H Cletrac running... Reply to specific post Reply with quote
Good to hear!
Dugger
PostPosted: Fri Dec 21, 2018 4:51 pm    Post subject: Re: Doubt I can get this BGS-H Cletrac running... Reply to specific post Reply with quote
[quote="mopardude318"](reply to post at 12:24:43 11/14/18) [/quote]
I noticed the freeze plugs are busted
It either froze at one time or they rusted out
Better check those
mopardude318
PostPosted: Sat Dec 22, 2018 8:23 pm    Post subject: Re: Doubt I can get this BGS-H Cletrac running... Reply to specific post Reply with quote
Better check those
Yes thank you. I pulled the starter, water pump, distributor housing, and oil filter housing so I can replace all 6 of those on the side of the block.
I ordered a rebuilt water pump/distributor housing,drive gear all from Zimmerman's as mine was all complete toast. lol. more pics to come.
Allan B.
PostPosted: Tue Jan 08, 2019 5:19 am    Post subject: Re: Doubt I can get this BGS-H Cletrac running... Reply to specific post Reply with quote
Great quality photos. My BGSH has pretty much the same issues yours did. Where did you end up getting new engine gaskets - Zimmermans? How
about the radiator gaskets? Thanks
Dugger
PostPosted: Tue Jan 08, 2019 5:55 am    Post subject: Re: Doubt I can get this BGS-H Cletrac running... Reply to specific post Reply with quote
[quote="mopardude318"](reply to post at 11:24:00 12/18/18) [/quote]
It always makes you feel good when you hear
The dead come alive after some hard work and
Busted knuckles
Good luck
mopardude318
PostPosted: Mon Jan 14, 2019 10:23 am    Post subject: Re: Doubt I can get this BGS-H Cletrac running... Reply to specific post Reply with quote
CVPost-Allan B. wrote:
(quoted from post at 06:19:47 01/08/19) Great quality photos. My BGSH has pretty much the same issues yours did. Where did you end up getting new engine gaskets - Zimmermans? How
Yes, I got all the gaskets I needed from Zimmermans. Same for the radiator gasket, which is just a peel and stick, you punch your own holes. Very easy.
Page 3 of 3
