Differences in MS carburetors??
Goto page 1, 2  Next
Eman85
PostPosted: Thu Jan 10, 2019 5:41 pm    Post subject: Differences in MS carburetors?? Reply to specific post Reply with quote
I have what should be the original MS carb on my 51 8N and it has MS cast in the bowl and TSX33 stamped on it.
I have an old carb from a friend's 8N and it has MS cast at the mounting flange and has a brass tag with TSX 241B 4-54 on it.
What is any are the differences in these 2 carbs? I see on this site they list different kits.
If I was going to rebuild mine are the kits on this site the ones to use?
Gaspump
PostPosted: Thu Jan 10, 2019 7:24 pm    Post subject: Re: Differences in MS carburetors?? Reply to specific post Reply with quote
9/2/8N gas tractors used M/S carbs TSX-33,241,241A,241B and 241C carbs. most were improvements over the previous model, some like the 241C were less than suitable designs. Ford Tractor and M/S then decided that the TSX-241B was the best version and obsoleted all but the TSX-241B. All versions of the mentioned carbs should be rebuilt to TSX-241B specs so but the 241B kit. Differences were minor, mostly in the jets, biggest variant was the economizer jet at first it was too small then larger then none at all and finally going to the the TSX-241B setup.
Eman85
PostPosted: Thu Jan 10, 2019 9:45 pm    Post subject: Re: Differences in MS carburetors?? Reply to specific post Reply with quote
OK, What is the difference or improvement from the TSX33 to the 241B? Is the TSX33 the original for my 51? I'm not worried for restoration reasons, just wondering. Also there are different kits listed for the TSX33 and the 241B so there must be a physical difference somewhere.
All of that said should I just rebuild and use the 241B if it's a better design?
Farmer Dan
PostPosted: Fri Jan 11, 2019 3:13 am    Post subject: Re: Differences in MS carburetors?? Reply to specific post Reply with quote
241B would be correct for your 8N. THe 33 will work in a pinch but the 241B is the best of the bunch.
WW2N
PostPosted: Fri Jan 11, 2019 4:32 am    Post subject: Re: Differences in MS carburetors?? Reply to specific post Reply with quote
As said 241 for your 8N I have rebuilt and ran 33s 241s TSX 38s on 9Ns 2Ns and 8Ns
they all do a fine job. Just dont buy a import carburetor you will be sorry.Mikes
Carburetors use to have Made in the USA kits. The best running adjs are bottom the
main needle and back out two full turns, idle needle bottom it and back out one full
turn. And set the engine idle where you want it.
Eman85
PostPosted: Fri Jan 11, 2019 11:56 am    Post subject: Re: Differences in MS carburetors?? Reply to specific post Reply with quote
What did the 33 come on? I get the idea that the 241B is better but I sure would like to know why. What makes it a better carb? These things are pretty primitive as far as carbs go so I wanted to know what is the difference.
I'll build the 241B then swap it to my tractor since my 33 is working fine.
Gaspump
PostPosted: Fri Jan 11, 2019 12:21 pm    Post subject: Re: Differences in MS carburetors?? Reply to specific post Reply with quote
Already mentioned that the economizers were the big problem with the early 33's. Initially they were way to small, the idle and power needles changed, some castings changed and so far as the TSX-241C is concerned to was a cheap version of the B and again deleting the economizer. The TSX-241B was the happy combination of parts, most efficient and most trouble free. All carbs are suitable for use and if rebuilt with TSX-241B parts you can't beat any one of them.
Tim PloughNman Daley
PostPosted: Sat Jan 12, 2019 11:59 am    Post subject: Re: Differences in MS carburetors?? Reply to specific post Reply with quote
Marvel-Schebler supplied the carbs for Ford tractors. The TSX-33 was used from 1939 thru early 8N production. Then in 1948, they released the TSX-241 unit - a little bit better designed part with subsequent revisions at B,C, and D. The TSX-38 was the Industrial Unit, used mostly on warhorse 2Ns as it had the double throw choke lever. ALL units operate the same way, and will work just fine on N's. The TSX-241-B carb your buddy has will work fine. Get the complete carb kit -usually about 40-50 bucks. The low budget kits do not have very many useful parts in them. I do not know what they sell her -they sell parts from several different suppliers, don't rely on one brand, nor make any parts themselves, so that is your prerogative whom you buy from. I but my kits on-line, complete. If you want, send me your carb and I will rebuild it professionally, guaranteed to fire right up with little or no tweaking required. My email is open and do not toss out your TSX-33 unit. The 8N and later M/S Carbs used a brass ID tag riveted on the Ping-Pong paddle boss. It had the TSX Model number and a date code stamp of when the carb was manufactured. Your TSX-241-B is perfect for your '51 8N, and the date code is 4-54 -April,1954. That means nothing other than the mfg date. Marvel-Schebler was part of the Borg-Warner Corporation but M/S is no longer in business. It is still highly recommended that you rebuild their carbs before thinking of buying anything made new today. Most new stuff is junk -carbs, distributors, water pumps, generators, starters, et al. ALL of these parts were engineered to be rebuilt over and over again. If the OEM carb hasn't been mucked up by someone trying to drill or ream open any passages, or stripping out any fine threads, it will work fine once cleaned inside and out and rebuilt correctly.
Tim *PloughNman* Daley(MI)
Royse
PostPosted: Sat Jan 12, 2019 5:39 pm    Post subject: Re: Differences in MS carburetors?? Reply to specific post Reply with quote
"I get the idea that the 241B is better but I sure would like to know why. What makes it a better carb?"
Nothing. That's an old wive's tale that gets repeated constantly.
Make sure your TSX-33 has an economizer jet in it and run it.
This kit on YT will get it done for ~$30 plus shipping.
This one comes complete with butterflies, drain valve, elbow screen and screws for $55.
I have used both with good results. Note that they fit 241 A/B/C.
I've never seen any documentation on a 241D.
As far as I can tell, there are two main aftermarket suppliers.
Tisco and A&I. Pick your poison. I have not had much luck with A&I.
If you'd like help doing the rebuild yourself, my email is open.
This is one of the many TSX-33's I've rebuilt.
Eman85
PostPosted: Sat Jan 12, 2019 6:11 pm    Post subject: Re: Differences in MS carburetors?? Reply to specific post Reply with quote
Interesting on the complete kits the 33 is a separate kit from the 241B but the comprehensive kit covers both carbs.
First I have no intention of using an aftermarket carb when I have 2 originals.
For whatever reasons it looks like the 33 wasn't the factory carb for my tractor. It performs fine though. Seems odd though as most everything else was untouched and I've had it over 30 years. I know somewhere along the line I've had it apart for a cleaning but that was 25 years ago.
I have a few projects going on right now and the N is running good. Rebuilding the carb will happen, just a little later. I've done a lot of carbs but mostly auto and motorcycle carbs. cast iron carbs aren't common on cars, but I have done a brass Linkert from my Harley.
Royse
PostPosted: Sat Jan 12, 2019 7:02 pm    Post subject: Re: Differences in MS carburetors?? Reply to specific post Reply with quote
Here's the answer to your question about which carbs were used
when. I searched my docs for this service bulletin and could not
locate it quickly, so I had to use the "phone a friend" option.
Thanks Gary! Smile
Note that the service bulletin says the difference is in the venting
and the specific instructions on how the two should be adjusted is
different. It also says the 8N carb, a.k.a 241 should be replaced if
it cannot be adjusted appropriately. I don't believe they need to
be replaced, nor do they need to be adjusted much differently
today. Use the complete or comprehensive kit and adjust it per
the operators manual. Start at 1 and 1/2 out on the main adjuster
and 1/2 turn out on the idle air adjuster.
Did you know you were supposed to tighten the screws in a
specific order? It was recommended on many car carbs too.
If these aren't clear enough to read, I can email them to you.
GB in MT.
PostPosted: Sat Jan 12, 2019 7:24 pm    Post subject: Re: Differences in MS carburetors?? Reply to specific post Reply with quote
"I searched my docs for this service bulletin and could not
Thanks Gary! Smile "
Any time LR.
I tell people to save these to their files, and print them out. Makes the doc. very readable!!!
Gary
alias...GB in MT. Cool
R Geiger
PostPosted: Sat Jan 12, 2019 7:33 pm    Post subject: Re: Differences in MS carburetors?? Reply to specific post Reply with quote
"Did you know you were supposed to tighten the screws in a
specific order? It was recommended on many car carbs too. "
All I see in my M/S section is " tighten screws gradually until all are tight"
Royse
PostPosted: Sat Jan 12, 2019 7:41 pm    Post subject: Re: Differences in MS carburetors?? Reply to specific post Reply with quote
Hopefully, we all learn something new every day! Smile
R Geiger
PostPosted: Sat Jan 12, 2019 8:02 pm    Post subject: Re: Differences in MS carburetors?? Reply to specific post Reply with quote
Well, guess I did learn someting today!! any idea why?
can you tell from this photo which one is M/S carb? All three are cast iron.
Goto page 1, 2  Next
Page 1 of 2
