AC question
Goto page 1, 2  Next
sodly
PostPosted: Thu Jan 10, 2019 8:16 pm    Post subject: AC question Reply to specific post Reply with quote
Please bear with this AC newbie. What was the first AC tractor (under 100 hp) to have an independent PTO? I mean, on the D series when you pushed the foot clutch the PTO stopped turning. What was the first AC tractor that the PTO continued operation even when the foot clutch was depressed? Did any of the 100 series tractors have this feature?
Bob Bancroft
PostPosted: Fri Jan 11, 2019 1:15 am    Post subject: Re: AC question Reply to specific post Reply with quote
The One-Sixty/160 had a two stage engine clutch, both stages being controlled by the foot pedal. This tractor was AC in name only as it was built by Renault.
16-30 oilpull
PostPosted: Fri Jan 11, 2019 2:42 am    Post subject: Re: AC question Reply to specific post Reply with quote
I have a D-10 with live independent PTO. My earlier D-12 does not so was that an option or just on the later ones?
Bob Bancroft
PostPosted: Fri Jan 11, 2019 3:11 am    Post subject: Re: AC question Reply to specific post Reply with quote
There were no D10-D12's around here, so I have no experience with them. I believe they got up to a series III, so changes were obviously made. I don't believe live PTO was an earlier option, but came later, as with your tractors.
Traditional Farmer
PostPosted: Fri Jan 11, 2019 3:24 am    Post subject: Re: AC question Reply to specific post Reply with quote
5040 had LPTO
DrAllis
PostPosted: Fri Jan 11, 2019 5:24 am    Post subject: Re: AC question Reply to specific post Reply with quote
Early generation D10-12's did NOT have a live or independent PTO, but they did have a PTO. I believe it was the Series 2 and 3 models that had a truly independent PTO similar to what Oliver used.
sodly
PostPosted: Fri Jan 11, 2019 7:14 am    Post subject: Re: AC question Reply to specific post Reply with quote
DrAllis wrote:
(quoted from post at 06:24:10 01/11/19) Early generation D10-12's did NOT have a live or independent PTO, but they did have a PTO. I believe it was the Series 2 and 3 models that had a truly independent PTO similar to what Oliver used.
The reason I bring this up is because I've often fancied owning a D-series or a 100 series tractor but would need to be able to do chores like bush-hogging with it. However, I'm told the Power Director really makes that difficult if you have a lot of backing up to do. The foot clutch kills the PTO every time you step on it to change from forward to reverse-- not ideal with a mower behind you.
So the later D10 and D12s have an live PTO where you can push the clutch down part way to stop the tractor without stopping the PTO? But the D15 and D17 tractors did not?
Were there any other later AC tractors (besides the 160) that had this ability? Or an independent PTO that ran regardless of the foot clutch? The 170... 180... 190... 200? I'm not that familiar with all of them and how they differ from one another. Not interested in a foreign-built model.
Bob Bancroft
PostPosted: Fri Jan 11, 2019 7:25 am    Post subject: Re: AC question Reply to specific post Reply with quote
I don't know how the later D10-D12 PTO was engaged. Whether a two stage engine clutch, or a separate clutch in the rear. A look at the parts diagram would be instructional. I will guess it's a separate clutch, as I don't recall AC using a double clutch.
The D14-15-17-19, as well as the 170-175-180-185-190-190XT-200 all worked the same way- engine clutch stopped PTO. Use the "power director" to maintain PTO operation.
DrAllis
PostPosted: Fri Jan 11, 2019 7:27 am    Post subject: Re: AC question Reply to specific post Reply with quote
Anything with the Hi/Low Power Director clutch kills the PTO when you step on the foot clutch. For those of us who are used to it, it's not really that big of deal when the tractors hydraulic oil is fully warmed up. Many times you don't even need to step on the foot clutch to shift and if you do it is very quick with no time lost.
sodly
PostPosted: Fri Jan 11, 2019 7:39 am    Post subject: Re: AC question Reply to specific post Reply with quote
DrAllis wrote:
(quoted from post at 08:27:46 01/11/19) Anything with the Hi/Low Power Director clutch kills the PTO when you step on the foot clutch. For those of us who are used to it, it's not really that big of deal when the tractors hydraulic oil is fully warmed up. Many times you don't even need to step on the foot clutch to shift and if you do it is very quick with no time lost.
Thanks for the update guys. That's what I suspected.
Dr Allis, you can shift from forward to reverse without the clutch?!!?
old
PostPosted: Fri Jan 11, 2019 8:50 am    Post subject: Re: AC question Reply to specific post Reply with quote
I have a number of A/C tractors. On my WD45 you can shift form forward to reverse using the hand clutch but on my D-17 I cannot do that.
Brian G. NY
PostPosted: Fri Jan 11, 2019 9:31 am    Post subject: Re: AC question Reply to specific post Reply with quote
CVPost-old wrote:
(quoted from post at 17:50:00 01/11/19) I have a number of A/C tractors. On my WD45 you can shift form forward to reverse using the hand clutch but on my D-17 I cannot do that.
Interesting......
I can't with either my WD or WD-45 but I can with the D-17 if I do it quickly. That works out well as I do most of my bushhoggin' with the D-17.
sodly
PostPosted: Fri Jan 11, 2019 11:04 am    Post subject: Re: AC question Reply to specific post Reply with quote
Brian G. NY wrote:
(quoted from post at 10:31:39 01/11/19)
Interesting......
How is this even possible if the tractor is rolling forward to shift into reverse without the (foot) clutch? Or vice versa?
Bob Bancroft
PostPosted: Fri Jan 11, 2019 11:34 am    Post subject: Re: AC question Reply to specific post Reply with quote
As you can see, it's not so much the model, but it's conditional factors. You can shift with the power director, or hand clutch, if, the tractor ground travel is stopped, the oil is warm, your clutch is in good working order [no warped plates] your shifter is in good condition, you're fast, and know what you're doing!
old
PostPosted: Fri Jan 11, 2019 12:26 pm    Post subject: Re: AC question Reply to specific post Reply with quote
That's odd. On my WD45 I can shift gear using the hand clutch but I cannot shift gears on my D-17 with the hand clutch
Goto page 1, 2  Next
Page 1 of 2
