Bleeding Belly pump
Buddy Woodson
PostPosted: Fri Jan 11, 2019 10:29 am    Post subject: Bleeding Belly pump Reply to specific post Reply with quote
Any tricks to bleeding the belly hydraulic pump after a rebuild?
Thanks
TheOldHokie
PostPosted: Fri Jan 11, 2019 10:50 am    Post subject: Re: Bleeding Belly pump Reply to specific post Reply with quote
CVPost-buddy woodson wrote:
(quoted from post at 14:29:19 01/11/19) Any tricks to bleeding the belly hydraulic pump after a rebuild?
Thanks
You do not need to bleed the pump. It will take care of itself.
TOH
Hobo,NC
PostPosted: Fri Jan 11, 2019 4:09 pm    Post subject: Re: Bleeding Belly pump Reply to specific post Reply with quote
Whats the problem....
May not have a thang to do with it this was a unusual problem Chris Keasler N would not lift. He straighten the lift control rod that goes in the pump it put the control valve linkage in a bind. From what he told me the rod is suppose to have a slit bend to the left of the tractor he took the bend out that was his problem... He went back and bent it to the left it freed up....
The lift linkage will cam over and do nuttin if it gets in a bind Wink it will make you think its working...
