Oil pan bolt torque
420Ron
PostPosted: Sun Jan 13, 2019 6:17 am    Post subject: Oil pan bolt torque Reply to specific post Reply with quote
I'm replacing the oil pan gasket on my 1957 JD 420W. I have purchased every manual , parts numbers, service manuals and have the original owners
manual. I'm searching for information on the oil pan bolt torque. Thank you for your consideration,Ron
Jim.ME
PostPosted: Sun Jan 13, 2019 8:44 am    Post subject: Re: Oil pan bolt torque Reply to specific post Reply with quote
Oil pan bolts, and other miscellaneous hardware, were not considered "critical" like heads,rods,etc., so specific torque specs often were not given by manufacturers, not just JD. At best a manual may have had a chart of fastener sizes and grades with torque for that type hardware. These charts are commonly found in newer manuals. Lacking a specific torque for oil pan bolts in a manual, I would use a generic chart for the size, grade, and pitch bolt used. Oil pan and valve cover hardware often gets tightened too tight,distorting the metal leading to leaks. JMHO
David G
PostPosted: Sun Jan 13, 2019 9:33 am    Post subject: Re: Oil pan bolt torque Reply to specific post Reply with quote
Just snug them up, worst thing is over torque as it distorts the gasket,
Bob
PostPosted: Sun Jan 13, 2019 9:49 am    Post subject: Re: Oil pan bolt torque Reply to specific post Reply with quote
If no "specs" are given for the stamped-steel oilpan I'm tightening (usually 1/4" or 5/16" capscrews) I typically use a "nutdriver" and snug 'em up by feel.
Better that ralphing on them with a ratchet or breaker bar, and they can always be snugged up a little more later.
That being said, some torque "specs" I have seen for oilpan screws range from basic 4 to 7 foot pounds for 1/4" screws, up to 15 foot pounds or so for 5/16" screw.
(I multiply torque value X 12 and use a 1/4" drive inch-pound torque wrench.)
420Ron
PostPosted: Sun Jan 13, 2019 12:06 pm    Post subject: Re: Oil pan bolt torque Reply to specific post Reply with quote
Thanks gentlemen,Ron
Rex Simpkins
PostPosted: Mon Jan 14, 2019 3:21 am    Post subject: Re: Oil pan bolt torque Reply to specific post Reply with quote
I usually use a 3/8 ratchet and put my hand around the head of the ratchet and turn until tight not using the handle of the ratchet at all. Has worked well for me a few decades
David G
PostPosted: Thu Jan 17, 2019 3:27 pm    Post subject: Re: Oil pan bolt torque Reply to specific post Reply with quote
I do the same.
