Wiring harness?
Goto page 1, 2  Next
Asher
PostPosted: Sun Feb 10, 2019 7:37 am    Post subject: Wiring harness? Reply to specific post Reply with quote
Since I am elbow deep in this Jubilee, and looking at the hacked up wiring harness (pet peeve of mine). Should I invest the time to make a harness, or are the wiring kits offered decent enough? The price on the kits seems very cheap, but like everything else for these tractors there is very little detail in the description. This tractor has everything in the factory places the only electrical change is that it was converter to 12v.
I like the idea of the kit, because I know if i build the harness it going to cost alto more since I am sure I will get carried away and include a modern fuse panel, relays for switches, soldering, heat shrink, etc and be $100 deep into a $20 harness.
Walston
PostPosted: Sun Feb 10, 2019 8:39 am    Post subject: Re: Wiring harness? Reply to specific post Reply with quote
I got a wiring harness from Dennis Carpenter when I restored my jubilee a few years ago. I was very happy with the quality and everything works well as designed.
R Geiger
PostPosted: Sun Feb 10, 2019 8:40 am    Post subject: Re: Wiring harness? Reply to specific post Reply with quote
I have used 2 wiring harnesses on my 8n and who do so again in a heart beat over making my own.
hunkydory
PostPosted: Sun Feb 10, 2019 9:52 am    Post subject: Re: Wiring harness? Reply to specific post Reply with quote
I'm in the same boat: My '50 front distributor appears to have the original wiring and a lot of the insulation is breaking down.
Dennis Carpenter offers "Main Wiring Assembly-Less Spk Pg Wires
1948 - 50" for $89.95. Our hosts offer "Ford 8N Wiring Harness, 6 Volt" for $19.59.
Is it worth spending the extra $70? She is not destined to be a show queen.
Hobo,NC
PostPosted: Sun Feb 10, 2019 10:57 am    Post subject: Re: Wiring harness? Reply to specific post Reply with quote
hunkydory wrote:
(quoted from post at 23:52:40 02/10/19) I'm in the same boat: My '50 front distributor appears to have the original wiring and a lot of the insulation is breaking down.
NO use the cheaper one even on 12V's... Everything should lay out for a alternator you will have to tie some wires together where it mounted to the voltage regulator...
For the guys that like to roll there on that's OK if you stock all the wire colors and wire sizes with the proper terminals but paying me $100 a hour to do it is nonsense...
Asher
PostPosted: Sun Feb 10, 2019 3:39 pm    Post subject: Re: Wiring harness? Reply to specific post Reply with quote
You guys are the best!!! Wire kit it is!!!
I am already getting in hot water with the
tractor home in the garage and the wife's
car outside in the MO snow and ice storms
lately.
I think I figured out the lift problem
(stuck unloading valve). So some cleaning,
seal replacements and fingers crossed.
hunkydory
PostPosted: Sun Feb 10, 2019 4:24 pm    Post subject: Re: Wiring harness? Reply to specific post Reply with quote
Thank you!
Tim PloughNman Daley
PostPosted: Mon Feb 11, 2019 3:41 am    Post subject: Re: Wiring harness? Reply to specific post Reply with quote
The cheaper versions, and there are many sold today, are mostly junk IMHO. They use 18 GA vinyl covered wires that can and will fail in short time (pun intended). I would avoid those. I?ve had the vinyl wear off and short out, I?ve had some sets that had incorrect lengths, coming up short on one wire so I had to splice my own patch in. Dennis Carpenter makes exact-as-original wiring harnesses, cloth covered, correct color codes with and without the headlight wiring. just 8n's sells all the Carpenter stuff too as the founder was DC?s QC man when he first started. Many other suppliers sell the DC stuff too only they mark them up 10-20 percent. It does matter who you buy from. I use a place called Agri-Services based in New York, owner is Jim Guarino ?click on LINK below. He makes EXACTLY as original wiring harnesses, made me one for my early 9N and early 8N too. I won?t buy cheap wiring ever again. It?s your tractor, invest whatever you want. Just giving you options because YOU ASKED.
Tim *PloughNman* Daley(MI)
WIRING HARNESSES
ASEguy
PostPosted: Mon Feb 11, 2019 4:21 am    Post subject: Re: Wiring harness? Reply to specific post Reply with quote
I purchased a new wiring loom for my 8N because the wiring was original and was falling apart. I also purchased split loom in a roll for all the wires to avoid the wires rubbing through the insulation. I believe my tractor has only one fuse and having circuits without fuses bothers me. I also use split loom on hydraulic hoses when there may be contact with metal surfaces. Split loom is cheap insurance.
doublebass73
PostPosted: Mon Feb 11, 2019 5:29 am    Post subject: Re: Wiring harness? Reply to specific post Reply with quote
I actually design wiring harnesses for a living so when I added lights to my 9N I thought about just building a harness myself but when I saw that Dennis Carpenter sells an OEM style harness for $43 it was a no brainer, I just bought that. The lengths were perfect and everything connected up nice and easy.
hunkydory
PostPosted: Mon Feb 11, 2019 6:00 am    Post subject: Re: Wiring harness? Reply to specific post Reply with quote
That's a good idea. I have rolls of it around and use it on many other vehicles.
Hobo,NC
PostPosted: Mon Feb 11, 2019 9:40 am    Post subject: Re: Wiring harness? Reply to specific post Reply with quote
OEM 6V 8N harness used for a 12V conversion you will end up with a extra wire you can use that harness on a 9/2N are a 8N and use the extra wire for the headlights... Wink
Goto page 1, 2  Next
Page 1 of 2
