My first 8N 1951 SN# *8N356218*
Goto page 1, 2, 3 ... 9, 10, 11  Next
Lance-W
PostPosted: Sun Feb 17, 2019 2:45 pm    Post subject: My first 8N 1951 SN# *8N356218* Reply to specific post Reply with quote
Hello,
I've been looking for an 8N for about a year now. I finally found the one I was looking for in Lakeside (near El Cajon, Ca.)
A little about me. I like old stuff ! I've restored tons of stuff all the way from 60's vintage Camaros, Chevelles, Mustangs to a couple of military vehicles and recently a Monarch Lathe.
So what can the experts here tell from the pictures? It runs, it moves forward and backward, the hydraulics work. The gas tank and the carb were very bad. I have a feeling it sat for a very long time before I got my hands on it. The gas tank was the worst smelling gas I've ever smelled. The original carburetor is tucked away for future resto. It has a 51 date stamp on the tag so it might be the original.
Here's a couple of links to other things I have restored.
1968 Mule
https://forums.g503.com/viewtopic.php?f=79&t=267953
1942 Monarch 10EE
https://www.practicalmachinist.com/vb/monarch-lathes/my-first-monarch-10ee-5-42-round-dial-s-n-13938-a-343608/
I guess there's a 4 picture limit?
Lance-W
PostPosted: Sun Feb 17, 2019 2:46 pm    Post subject: Re: My first 8N 1951 SN# *8N356218* Reply to specific post Reply with quote
Is there supposed to be a thermostat in this hose??
John in Mich
PostPosted: Sun Feb 17, 2019 4:03 pm    Post subject: Re: My first 8N 1951 SN# *8N356218* Reply to specific post Reply with quote
That looks like a very solid base for a restoration. Yes, there should be a thermostat in the upper
radiator hose. Some come with a replacement hose and clamped in place with either a band. Other hoses
required a thermostat be inserted and a hose clamp added.
What is your plan to use the tractor?
hunkydory
PostPosted: Sun Feb 17, 2019 4:08 pm    Post subject: Re: My first 8N 1951 SN# *8N356218* Reply to specific post Reply with quote
If you restore that 8N like you did the other restorations you posted it will be wonderful to behold. You certainly have an eye for details!
Hobo,NC
PostPosted: Sun Feb 17, 2019 6:46 pm    Post subject: Re: My first 8N 1951 SN# *8N356218* Reply to specific post Reply with quote
Whut are your plans do you have a use for it are do you just want to take it apart and play with it for fun...
Lance-W
PostPosted: Sun Feb 17, 2019 7:58 pm    Post subject: Re: My first 8N 1951 SN# *8N356218* Reply to specific post Reply with quote
This one will earn it's keep everyday. It will not be a garage queen.
My wife manages/runs/teaches at a horse barn in Moorpark. It will work there everyday. Which means at some point in the future I will be doing this all over again.
Richard G.
PostPosted: Mon Feb 18, 2019 4:12 am    Post subject: Re: My first 8N 1951 SN# *8N356218* Reply to specific post Reply with quote
Good looking 8N. It will do a lot of work for you.
I have an old Monarch lathe that is much older. I always figured it was about WWI vintage. Has about a 6 foot bed on it. Flat belt driven from overhead shaft. I have an electric motor overhead on it now. Always wanted a manual for it but have not found one I can afford.
Richard in NW SC
TheOldHokie
PostPosted: Mon Feb 18, 2019 4:45 am    Post subject: Re: My first 8N 1951 SN# *8N356218* Reply to specific post Reply with quote
Lance-W wrote:
(quoted from post at 23:58:12 02/17/19) This one will earn it's keep everyday. It will not be a garage queen.
That 10EE is too pretty to be earning it's keep :roll:
TOH
Hobo,NC
PostPosted: Mon Feb 18, 2019 5:51 am    Post subject: Re: My first 8N 1951 SN# *8N356218* Reply to specific post Reply with quote
I would get it up and running use it before I dug into it deep... The only thing that popped out at me was the way they mounted the coil its not a deal killer the coil is mounted different on a original side mount dist head so I would guess the head has been replaced..
On the rear top link rocker for the tree point never use the top two
holes block them off so no one else does...
The next question what work will it do on the hobby horse farm... Hobby horse farms need a loader tractor a N is not a loader tractor...
Tim PloughNman Daley
PostPosted: Mon Feb 18, 2019 6:02 am    Post subject: Re: My first 8N 1951 SN# *8N356218* Reply to specific post Reply with quote
The best thing you can do is to invest in the essential manuals and read religiously if you haven't already done so. Don't put much faith in serial numbers. Engines got swapped out often and unless you are planning on doing a full correct restoration, forget it. The important facts to know are, A) it has a side mount distributor, B) late steering box, I think, C) has a 12V switch out job, but I'd verify it has been done correctly. I see OEM Hat Rims and 16" fronts. You may want to check rear tires for Calcium Chloride and get rid of it -it will leak and corrode those original hats. Whatever that monstrosity is hanging off the RH dogleg I'd get rid of pronto. If it is as I suspect some sort of extra fuel filter, it's a fire hazard as well as being an unnecessary item. There are three fuel filters in the OEM system and no need to add any more.
FORD 8N TRACTOR ESSENTIAL OWNER/OPERATOR/PARTS/SERVICE MANUALS:
Tim *PloughNman* Daley(MI)
Lance-W
PostPosted: Mon Feb 18, 2019 6:29 am    Post subject: Re: My first 8N 1951 SN# *8N356218* Reply to specific post Reply with quote
If I had to speculate I'd say the engine had been recently rebuilt before it got parked. I ran compression test yesterday and it turned out to be 90 PSI +/- 2 PSI on all the cylinders. I've never seen a compression test that was that closely grouped.
I will look into the coil mounting, the bracket that's it's currently on is very wimpy so I had planned on changing that anyways.
It will do what the big Kubota front end loader that they already have can't or go where it won't fit. I understand that a N is not a front end loader. It'd be great if it was but oh well. Right now I see it's job as
1. Dragging the arena
2. Working in the barn aisles as a platform to haul all the muck tubs to the dumping spot.
3. As a platform to feed off of.
2 & 3 will of course require me to build some type of trailer or I've been rolling around the idea of making a platform that attaches to the 3 point. Kinda like a variable height bed on the back of the tractor. Sound feasible?
Lance-W
PostPosted: Mon Feb 18, 2019 6:34 am    Post subject: Re: My first 8N 1951 SN# *8N356218* Reply to specific post Reply with quote
CVPost-Tim PloughNman Dal wrote:
(quoted from post at 07:02:39 02/18/19) The best thing you can do is to invest in the essential manuals and read religiously if you haven't already done so. Don't put much faith in serial numbers. Engines got swapped out often and unless you are planning on doing a full correct restoration, forget it. The important facts to know are, A) it has a side mount distributor, B) late steering box, I think, C) has a 12V switch out job, but I'd verify it has been done correctly. I see OEM Hat Rims and 16" fronts. You may want to check rear tires for Calcium Chloride and get rid of it -it will leak and corrode those original hats. Whatever that monstrosity is hanging off the RH dogleg I'd get rid of pronto. If it is as I suspect some sort of extra fuel filter, it's a fire hazard as well as being an unnecessary item. There are three fuel filters in the OEM system and no need to add any more.
The "thing" hanging off the dogleg is the temporary gas tank. VERY temporary. I already have a replacement gas tank/filters but at this point it's not worth changing it out.
No Calcium Chloride in the tires, Just air. The new tires are showing up tomorrow so the VERY cracked ones that are on there will be replaced as soon as I get the existing ones off, sand blast the wheels and epoxy prime and then paint them.
Hobo,NC
PostPosted: Mon Feb 18, 2019 8:47 am    Post subject: Re: My first 8N 1951 SN# *8N356218* Reply to specific post Reply with quote
Hi-Tek hobby horse farm with a bota :)... Look into sway bar links and mounts for the 3 point someone will post a pix of them in use...
https://www.yesterdaystractors.com/231253XHD_Stabilizer-Kit-Extra-Heavy-Duty_782.htm
johnmspeight
PostPosted: Mon Feb 18, 2019 9:09 am    Post subject: Re: My first 8N 1951 SN# *8N356218* Reply to specific post Reply with quote
I have a 1952 (?), 8N - I understand firing order from distributor is I 2 4 3 - However I have gotten different opinions about numbering of pistons - is # 1 closest to radiator or closest to steering wheel ? Thank You to whoever answers.
HFJ
PostPosted: Mon Feb 18, 2019 9:50 am    Post subject: Re: My first 8N 1951 SN# *8N356218* Reply to specific post Reply with quote
hi john, welcome to YT.
number one cylinder is at the front, closest to the radiator.
Page 1 of 11
