JD RWA parts
OldFarmall450
PostPosted: Mon Mar 11, 2019 7:41 am    Post subject: JD RWA parts Reply to specific post Reply with quote
I have located a 12' disk harrow, the owner says its a RWA, it has a bad axle bearing. The owner pulled the gang and bearing, but got tired of working on it.
How hard is it to replace the bearing? I see them listed online, from $9.99 to $100.00. I also saw the bearing housing halfs for sale. Can I just buy 2 of these, a bearing, and clamp them together?
Anything I need to know about the RWA? Good or bad?
Thanks guys.
Tx Jim
PostPosted: Mon Mar 11, 2019 9:19 am    Post subject: Re: JD RWA parts Reply to specific post Reply with quote
JD RWA disk harrow are notorious for ridging the soil. If I was looking for a disk harrow it would not be a JD RWA.
OldFarmall450
PostPosted: Mon Mar 11, 2019 9:22 am    Post subject: Re: JD RWA parts Reply to specific post Reply with quote
What if it can be had for under 500 bucks?
DeltaRed
PostPosted: Mon Mar 11, 2019 10:20 am    Post subject: Re: JD RWA parts Reply to specific post Reply with quote
I once had a 10' RWA. Nice little disk,but would tend to ridge.That could be somewhat 'remedied' by setting the front disks a bit deeper than the rear.I'm more concerned about bearings. Are they the old cast iron 'boxing' type,or regular ball/roller bearings.IIRC,JD disk bearings are expencive.Unless it is CHEAP,I'd look for an Oliver,IH or something else.
OldFarmall450
PostPosted: Mon Mar 11, 2019 3:39 pm    Post subject: Re: JD RWA parts Reply to specific post Reply with quote
Delta, it was almost dark but im pretty sure it had the cast iron "box " that held the bearings. Ag center shows several bearings for the rwa.
SVcummins
PostPosted: Mon Mar 11, 2019 6:59 pm    Post subject: Re: JD RWA parts Reply to specific post Reply with quote
Buy it fiat cnh parts are no cheaper and Agco parts
are even more than John Deere
DeltaRed
PostPosted: Mon Mar 11, 2019 8:33 pm    Post subject: Re: JD RWA parts Reply to specific post Reply with quote
Like any other bearing. Dismntle the whole gang.
MoMike
PostPosted: Tue Mar 12, 2019 1:52 pm    Post subject: Re: JD RWA parts Reply to specific post Reply with quote
Yes, they do ridge, however I've found that by not running them to deep, 2 2 1/2" and not flying it doesn't do to bad. Remember these disk date to the late '50's and early 60's so they were meant to be pulled by 2 cylinder tractors with 3rd and 4th gear speed of
3 1/2 to 4 1/2 MPH. Does it have actual bearings or have the white iron type?
OldFarmall450
PostPosted: Tue Mar 12, 2019 5:44 pm    Post subject: Re: JD RWA parts Reply to specific post Reply with quote
CVPost-MoMike wrote:
(quoted from post at 14:52:16 03/12/19) Yes, they do ridge, however I've found that by not running them to deep, 2 2 1/2" and not flying it doesn't do to bad. Remember these disk date to the late '50's and early 60's so they were meant to be pulled by 2 cylinder tractors with 3rd and 4th gear speed of
As near as i can tell it has regular bearings in the cast-iron mounting.
OldFarmall450
PostPosted: Tue Mar 12, 2019 5:47 pm    Post subject: Re: JD RWA parts Reply to specific post Reply with quote
Like this
SVcummins
PostPosted: Thu Mar 14, 2019 11:17 am    Post subject: Re: JD RWA parts Reply to specific post Reply with quote
55 50 Ron
PostPosted: Thu Mar 14, 2019 11:49 am    Post subject: Re: JD RWA parts Reply to specific post Reply with quote
1/2 of that would be somewhere near a good price.
Tx Jim
PostPosted: Thu Mar 14, 2019 1:57 pm    Post subject: Re: JD RWA parts Reply to specific post Reply with quote
CVPost-SVcummins wrote:
(quoted from post at 15:17:45 03/14/19)
<img src="/cvphotos/cvphoto16523.jpg">
The statement about changing gang angle on a RWA doesn't apply as gangs have only one(1) angle that they can be set short of utilizing a cutting torch.
OldFarmall450
PostPosted: Thu Mar 14, 2019 3:00 pm    Post subject: Re: JD RWA parts Reply to specific post Reply with quote
Can someone tell me if the bearing in the cast- iron housing can be pressed out and a new one pressed in?
I've looked online and can't find a schematic.
Tx Jim
PostPosted: Fri Mar 15, 2019 2:31 am    Post subject: Re: JD RWA parts Reply to specific post Reply with quote
After removing snap ring brg can be pressed out/in of cast iron housing.
