1966 G1000 Wheatland Injector Pump removal
Goto page 1, 2  Next
MinniMan
PostPosted: Tue Apr 09, 2019 6:36 am    Post subject: 1966 G1000 Wheatland Injector Pump removal Reply to specific post Reply with quote
We have a G1000 Wheatland tractor which needs repairs to the injector pump. It is surging when running and from what I have read it has a fiber ring which is failing. The pump is fully operational at the moment but I don't want to damage it before repairs are made.
My question is what is the correct procedure to remove the pump for repairs. Does the engine need to be turned to a certain position so that when replacing the pump it will be in correct time?
I have never removed an injector pump on this tractor so will appreciate all advice.
SWMolines
PostPosted: Tue Apr 09, 2019 7:19 am    Post subject: Re: 1966 G1000 Wheatland Injector Pump removal Reply to specific post Reply with quote
Clean the area around the pump and all the injectors as best you can to keep dirt out.
To keep the pump in time with the engine:
First remove the rectangular cover with the two screws from the side of the pump to expose the timing marks inside the pump.
Then, rotate the engine until the pump timing marks are aligned. It is also a good idea to mark the flywheel just in case the engine should be nudged while working on it.
At that point, the pump can be removed and re-installed with the timing marks aligned and the engine should run as it did before the pump was removed (hopefully without the surging issue).
After installing the pump, all of the injection lines will need to be bleed to remove trapped air.
Not a difficult job.
MinniMan
PostPosted: Tue Apr 09, 2019 9:00 am    Post subject: Re: 1966 G1000 Wheatland Injector Pump removal Reply to specific post Reply with quote
Thank you very much SWMolines. Your step by step procedure is very much appreciated.
rustred
PostPosted: Tue Apr 09, 2019 5:08 pm    Post subject: Re: 1966 G1000 Wheatland Injector Pump removal Reply to specific post Reply with quote
just remove the pump after a wash job. don't make a bit of difference where the marks are. then... when u go to install the pump you get the engine on TDC on #1 cyl. line up the timing marks on the flywheel to factory spec. 705 is 11 degree's not sure if this one is the same. then.. you look in the pump and make sure the dot on the shaft is to the top. then you carefully slide it over the LUBED seals not to fold them. then you line up the timing marks in the pump window by turning the pump and tightening the two bolts.
just lining up pump marks don't tell you where the engine timing was set at , it could have been out of time all along. you need to go through the whole procedure. plus its a good idea to set the valve lash also to make sure you have a good running unit.
MinniMan
PostPosted: Tue Apr 09, 2019 6:21 pm    Post subject: Re: 1966 G1000 Wheatland Injector Pump removal Reply to specific post Reply with quote
Thank you Rustred. Additional information is always appreciated. Much easier to have a good understanding BEFORE removing parts because it makes replacing them much easier and more satisfactory. All suggestions and comments are welcome and appreciated.
SWMolines
PostPosted: Wed Apr 10, 2019 4:29 am    Post subject: Re: 1966 G1000 Wheatland Injector Pump removal Reply to specific post Reply with quote
It is always good to verify timing when working with an injection pump or distributor (magneto). I have come across several MMs that have had the flywheel indexed incorrectly over the years and the timing marks are not visible when #1 is at TDC.
That makes timing a diesel more complicated unless you have the head off the engine to determine TDC accurately.
MinniMan
PostPosted: Wed Apr 10, 2019 5:22 am    Post subject: Re: 1966 G1000 Wheatland Injector Pump removal Reply to specific post Reply with quote
Thanks for the heads up SWMolines. Now that would lead to a head scratcher.
The correct procedure would be to remove the front valve cover and make sure the intake valve is just closing on #1 cylinder. Then rotate the crankshaft a 1/2 revolution and hope to find the timing mark in the index window. If it is visible we are ok. If not we have a problem.
Why would the index marks not be positioned in the proper location? Is it possible to install the flywheel in any position on the crankshaft or was it a factory error in marking the timing marks? Usually the flywheel will only install on the crankshaft according to the spacing of the flywheel to crankshaft attaching bolts.
fossil
PostPosted: Wed Apr 10, 2019 8:55 am    Post subject: Re: 1966 G1000 Wheatland Injector Pump removal Reply to specific post Reply with quote
Surge may also come from a worn throttle shaft The worn elastoplastic ring bad will cause it to die when put from high speed to idle have a good diesel shop rebuild it for you .
SWMolines
PostPosted: Wed Apr 10, 2019 11:24 am    Post subject: Re: 1966 G1000 Wheatland Injector Pump removal Reply to specific post Reply with quote
The flywheel on G1000s and similar motors can be put on the crank in any of 6 positions (6 bolt pattern) relative to the crankshaft.
Your method of watching the intake valve close + 1/2 turn will get you close. Verifying the timing marks in the pump are aligned should get you spot on. And, as has been already stated, it is always good to verify the timing when re-installing the pump using the marks on the flywheel.
I have had at least one Vista with the timing marks about 120 degrees off from the crank and had to use a measuring tape to re-set the timing after someone else had rebuilt the motor and installed it on the tractor. I was lucky enough to have a fly wheel on the floor that I could get the measurements needed to time the pump.
MinniMan
PostPosted: Wed Apr 10, 2019 12:08 pm    Post subject: Re: 1966 G1000 Wheatland Injector Pump removal Reply to specific post Reply with quote
Thanks fossil.
No it doesn't die when idled down from high speed to low speed but rather idles unevenly and even at higher speeds surging. Yes having the pump overhauled is the plan. That is the reason I want to be sure that when I remove it I can replace it with the correct timing.
MinniMan
PostPosted: Wed Apr 10, 2019 12:12 pm    Post subject: Re: 1966 G1000 Wheatland Injector Pump removal Reply to specific post Reply with quote
To my knowledge this engine has never been apart so I am thinking the flywheel will be in its original position. Strange that there were no locating dowels or bolt pattern to align the flywheel with the crankshaft. Most I have come across couldn't be installed incorrectly. But never say never. Thanks for the further explanation SWMolines.
molinegb
PostPosted: Wed Apr 10, 2019 5:22 pm    Post subject: Re: 1966 G1000 Wheatland Injector Pump removal Reply to specific post Reply with quote
Just rebuild it yourself. Done several of my own. Don't have test stand but so far batting 1000. Have done the Bosch inline and
rotary also.
ChrisQ
PostPosted: Wed Apr 10, 2019 5:42 pm    Post subject: Re: 1966 G1000 Wheatland Injector Pump removal Reply to specific post Reply with quote
Dowel pins and bolts for the flywheel are equally spaced. I think it can be installed 8 different ways. Engine did not need to be apart for the flywheel to be off. Typically the flywheel is removed and resurfaced when a clutch is replaced. It more than likely has had a clutch in its lifetime.
MinniMan
PostPosted: Wed Apr 10, 2019 8:22 pm    Post subject: Re: 1966 G1000 Wheatland Injector Pump removal Reply to specific post Reply with quote
Hi ChrisQ
What you say is very true the flywheel could have been removed for resurfacing upon a new clutch installation. I suspect being in the 3500 hour range that is quite possible. However, I know this tractor did some field work but spent a lot of its time as a PTO tractor. The drawbar is not worn from pulling implements like one would expect from many hours in the field.
Still, I will proceed with due diligence when checking the timing of the pump before removal. I do appreciate all thoughts and comments since each person shines a new light on issues that could crop up.
MinniMan
PostPosted: Wed Apr 10, 2019 8:29 pm    Post subject: Re: 1966 G1000 Wheatland Injector Pump removal Reply to specific post Reply with quote
Hi molinegb
Now you are showing more confidence in me than I have in myself. You have a great deal more experience with the eccentricities of an injection pump than I do. But I do appreciate your vote of confidence.
I am waiting for a warm sunny day so the shop warms up a little before I tie into this project. So far we still seem to be enduring a nasty windy cool week minus the snow our neighbours to the south are getting.
Goto page 1, 2  Next
Page 1 of 2
